Topic: JScript Panel script discussion/help (Read 308256 times) previous topic - next topic
Re: JScript Panel script discussion/help
Reply #1225
JScript Panel 3.3.20 (Custom Track 3.1 by eurekagliese)
JavaScript runtime error
Unable to get property 'colour' of undefined or null reference
File: <main>
Line: 1931, Col: 4
Get this error when I play an album cover with an single color, seems to be the only issue I've found
Reply #1226
Can I set background color opacity in JSplaylist?
I want to peel off the mask of a beautiful girl in wallpaper.
But I'm ignorant. Could you please save the princess?
Thx!
Reply #1227
Thanks for bio scripts!
Reply #1228
Hello again, Marc. Is there any plan to add more features to the last.fm bio like fetch the artist's country flag, genre, and additional information like the layout on Wil-B's Biography.
I'm in the process of changing my mind on this. A preview...
Reply #1229
I'm looking forward to it.
SHURE SRH1840, SENNHEISER HD660S2, SENNHEISER HD 490 PRO, DT 1990 PRO, HiFiMAN Edition XS, Bowers & Wilkins P7, FiiO FT5, 水月雨 (MOONDROP) 空鳴 - VOID, Nakamichi Elite FIVE ANC, SONY WH-ULT900N (ULT WEAR) (made a Upgrade/Balanced Cable by myself)
Reply #1230
Here are some files for testing. Save the .js in the component folder\samples\js - the .txt goes in the panel. It's optional and can be turned off via the right click menu. The Twitter Color Emoji font is required for country flags.
Reply #1231
@marc2k3
panel crashes.
samples\js\text.js
Last.fm Bio + Images
JScript Panel 3.3.20 (Last.fm Bio + Images by marc2003)
JavaScript 実行時エラー
'_firstElement' は定義されていません。
File: C:\Users\teamf\Documents\Online Soft 03\foobar2000\foobar2000 DUIK x64 (STANDARD)\foobar2000\profile\user-components-x64\foo_jscript_panel3\samples\js\text.js
Line: 233, Col: 6
Reply #1232
@marc2k3
panel crashes.
samples\js\text.js
JavaScript 実行時エラー
Line: 233, Col: 6
replace "_firstElement" with "_.isElement" in text.js will fix it
Reply #1234
@seongbin
Many Thanks.
_.isElement
Line: 233
Line: 264
Line: 265
Reply #1235
@marc2k3
Could you arrange the three files in Reply #1233 ?
text.js, Last.fm Bio + Images.txt and common.js
Reply #1236
Good to see it's coming. Thank you!
File: <main>
Line: 1931, Col: 4
Thanks for the feedback, I'll look into it. For now, simply Reload the script whenever you play a song with a better album cover.
PS. Pardon me if the issue from my script is cluttering the thread.
Reply #1237
@marc2k3
Flag display
text.js, common.js and Last.fm Bio + Images.txt
Reply #1238
Pretty sure that only happens with the original code bundled with the component. If you really apply the .txt I attached, it should be fine. :/
edit: I'm attaching a zip with updated samples. It must be extracted manually into the component samples folder. Do this while fb2k is closed and then you can choose updated samples from the menu in the config window.
Reply #1239
Reply #1233 https://hydrogenaud.io/index.php/topic,110516.msg1036525.html#msg1036525
Reply #1230 https://hydrogenaud.io/index.php/topic,110516.msg1036520.html#msg1036520
text.js, common.js and Last.fm Bio + Images.txt.
I tried with these 3 files.
Reply #1238
samples
Flag is not displayed.
Reply #1240
Thx!
sorry,
×background color
○selected background color
It was a different sentence...
Reply #1241
Well it probably comes from applying that garbage fix from seongbin. Yes it was my fault for not attaching a required file in the first place but when you have no idea what the code is inside that function, you can't make stuff up and expect it to work.
It might have prevented the script error but it broke the html parsing. The results are cached so you need to delete those bad files.
To fix:
Close fb2k.
Open Explorer and go to profile folder\js_data. Search for files named lastfm.artist.extra.json and delete them all.
edit: but your screenshot in #1237 showed the font name and correctly extracted flag data. This definitely was because the .txt inside the panel had not been updated. How can anyone make any sense of this drivel. :/
Reply #1242
Creating a new Panel and loading Last.fm Bio + Images.txt.
Is there anyone who can successfully display the flag?
Reply #1243
@marc2k3
Sorry, my bad carelessly handling it.
And I found that "Korea, Republic of" cannt be parsed as expected, cuz it has one more comma.
For test you can use "The Black Skirts" as artist name.
Reply #1244
It's working fine here.
I just remove the sample folder from the configuration folder first and then replace it with the extracted files from latest sample.zip provided by Marc above.
Spoiler (click to show/hide)
Perhaps the only visible minor issue is the genre tags Case.
Reply #1245
@eurekagliese
I have it configured that way
I don't think you're doing anything unnecessary.
The tag is %country%, right?
Reply #1246
@eurekagliese
No, the latest Last.fm Bio + Images script by marc automatically retrieves the flags. It seems that it scrapes the artist profile from the last.fm site, therefore artists who don't have the "Born in" or "Founded in" won't have their nation flag displayed, unlike the Text Display script which depends on the country tag.
Perhaps, as workaround If the country flag is missing on Bio, loading the flag from tag like on Text Display can be might be used.
Reply #1247
@eurekagliese
Yes, I finally understand.
The genres of artists I listen to are mostly Indie and minor.
Thank you very much, that was helpful.
@marc2k3 Sorry for polluting the thread just for me.
Reply #1248
I've added title format support for country flags in the bio script. Extract the attached zip to the ROOT of the component folder. You should overwrite all files except the dll which is not bundled here.
The default is $country_flag(%country%) but if you need to edit it, hold Shift + Winkey>right click>Edit properties. Look for 2K3.TEXT.BIO.FLAG.TF.
Country tags always take precedence over what is found online.
Reply #1249
Thanks for the update Marc, it's working nicely!
