@eurekagliese
If you look closely, you can see that "Last.fm Bio + Image" is placed above and below.
It can be used for vertically long or almost square panels.
Could you please share "Last.fm Bio + Image" Script?
I'm sorry for always asking for your help.
It's not a problem at all. I'm happy to share.
Here's the code, of course the credit goes to Marc, I just changed tiny bit of it.
// ==PREPROCESSOR==
// @name "Last.fm Bio"
// @author "marc2003"
// @import "%fb2k_component_path%helpers.txt"
// @import "%fb2k_component_path%samples\js\lodash.min.js"
// @import "%fb2k_component_path%samples\js\common.js"
// @import "%fb2k_component_path%samples\js\panel.js"
// @import "%fb2k_component_path%samples\js\lastfm.js"
// @import "%fb2k_component_path%samples\js\thumbs.js"
// @import "%fb2k_component_path%samples\js\text.js"
// ==/PREPROCESSOR==
var margin = _scale(12);
var panel = new _panel();
var lastfm = new _lastfm();
var text = new _text('lastfm_bio', 0, 0, 0, 0);
var thumbs = new _thumbs();
text.paint = function (gr) {
var colour = thumbs.blur_img ? RGB(255, 255, 255) : panel.colours.text;
var colourh = thumbs.blur_img ? RGB(255, 255, 255) : panel.colours.highlight;
gr.WriteText(this.header_text(), panel.fonts.title, colourh, this.x, margin, this.w, panel.h - (margin * 2), DWRITE_TEXT_ALIGNMENT_LEADING, DWRITE_PARAGRAPH_ALIGNMENT_CENTER, DWRITE_WORD_WRAPPING_NO_WRAP, DWRITE_TRIMMING_GRANULARITY_CHARACTER);
if (this.text_layout) {
gr.WriteTextLayout(this.text_layout, colour, this.x, this.y + margin, this.w, this.ha, this.offset);
this.up_btn.paint(gr, colour);
this.down_btn.paint(gr, colour);
thumbs.image_containsxXY = function (x, y) {
return this.images.length && this.containsXY(x, y);
thumbs.move = function (x, y) {
this.mx = x;
this.my = y;
return this.containsXY(x, y);
thumbs.paint = function (gr) {
if (this.images.length) {
_drawImage(gr, this.blur_img, 0, 0, panel.w, panel.h, image.crop_top);
_drawOverlay(gr, 0, 0, panel.w, panel.h, 120);
this.image_xywh = _drawImage(gr, thumbs.images[thumbs.image], this.x, this.y, this.w, this.h, image.crop_top);
} else {
this.image_xywh = [];
thumbs.size = function () {}
thumbs.wheel = function (s) {
if (this.containsXY(this.mx, this.my)) {
if (this.images.length > 1) {
this.image -= s;
if (this.image < 0) {
this.image = this.images.length - 1;
if (this.image >= this.images.length) {
this.image = 0;
window.Repaint();
return true;
return false;
panel.item_focus_change();
function on_colours_changed() {
panel.colours_changed();
window.Repaint();
function on_download_file_done(path, success, error_text) {
text.download_file_done(path, success, error_text);
function on_font_changed() {
panel.font_changed();
window.Repaint();
function on_http_request_done(task_id, success, response_text) {
thumbs.http_request_done(task_id, success, response_text);
function on_item_focus_change() {
if (panel.selection.value == 0 && fb.IsPlaying) return;
function on_key_down(k) {
text.key_down(k);
thumbs.key_down(k);
function on_metadb_changed(handles, fromhook) {
if (fromhook) return;
text.metadb_changed();
thumbs.metadb_changed();
function on_mouse_lbtn_up(x, y) {
text.lbtn_up(x, y);
thumbs.lbtn_up(x, y);
function on_mouse_move(x, y) {
text.move(x, y);
thumbs.move(x, y);
function on_mouse_lbtn_dblclk(x, y) {
thumbs.lbtn_dblclk(x, y);
function on_mouse_rbtn_up(x, y) {
if (text.containsXY(x, y)) {
return panel.rbtn_up(x, y, text);
return panel.rbtn_up(x, y, thumbs);
function on_mouse_wheel(s) {
if (thumbs.wheel(s)) return;
text.wheel(s);
function on_paint(gr) {
panel.paint(gr);
thumbs.paint(gr);
text.paint(gr);
function on_playback_dynamic_info_track(type) {
if (type == 0) {
function on_playback_new_track() {
thumbs.playback_new_track();
function on_playback_stop(reason) {
if (reason != 2) {
function on_playback_time() {
thumbs.playback_time();
function on_playlist_switch() {
on_item_focus_change();
function on_size() {
panel.size();
var half = panel.h / 2;
thumbs.x = margin;
thumbs.y = margin;
thumbs.w = panel.w - (margin * 2);
thumbs.h = half - (margin * 2);
text.x = margin;
text.y = half;
text.w = panel.w - margin;
text.h = half;
text.size();
