Topic: JScript Panel script discussion/help (Read 308233 times) previous topic - next topic
Re: JScript Panel script discussion/help
Reply #1050
Solved.
I accidentally added the .js file too.
All you need is the txt file, in the samples directory.
Reply #1051
I suppose my advice about editing .js files was not good. A better alternative is to transplant the method that handles updates in to the .txt file that goes in the panel.
Inside a panel with the text display script, insert this directly after var albumart = new _albumart(0, 0, 0, 0);
albumart.metadb_changed = function () {
var img = null;
if (panel.metadb) {
img = panel.metadb.GetAlbumArt(this.properties.id.value);
if (this.img) this.img.Dispose();
this.img = null;
this.tooltip = this.path = '';
if (img) {
this.img = img;
this.img.StackBlur(50); // valid values are 2-254
this.tooltip = 'Original dimensions: ' + this.img.Width + 'x' + this.img.Height + 'px';
this.path = this.img.Path;
if (this.path.length) {
this.tooltip += '\nPath: ' + this.path;
window.Repaint();
Reply #1052
@marc2k3
A: Line 27   this.img.StackBlur(2); // valid values are 2-254
Is there no choice but to modify A to make AlbumArt not blurry?
SHURE SRH1840, SENNHEISER HD660S2, SENNHEISER HD 490 PRO, DT 1990 PRO, HiFiMAN Edition XS, Bowers & Wilkins P7, FiiO FT5, 水月雨 (MOONDROP) 空鳴 - VOID, Nakamichi Elite FIVE ANC, SONY WH-ULT900N (ULT WEAR) (made a Upgrade/Balanced Cable by myself)
Reply #1054
I know that.
context menu > Album art background ← normal condition.
Is it possible to add a blurred state and a switching option?
I'm sorry for taking up your precious time.
Reply #1055
I know that.
The code I posted earlier actually does that.
It's blurred by default and can be switched to normal if the album art is check on in context menu.
Reply #1056
@eurekagliese
I have already tried your script. thank you.
I thought it was great that you could easily switch between these two +1 functions with Option.
1.) Album Art normal
2.) Album Art Blur
3.) Text only
Reply #1057
@marc2k3
v3.3.5
Reply #1273 https://hydrogenaud.io/index.php/topic,110499.msg1033624.html#msg1033624
Enable blur effect
Reply #1058
Is there a script like this?
If you can edit Samples Script, you can probably create it, but I don't have that knowledge.
(Track Info + Seekbar + Buttons.txt etc...)
Now Playing Info
Reply #1059
Add a normal Text Display panel and make sure the album art option is turned off. Also, make sure vertical alignment is set to bottom.
Then on line 16, you should find this...
var text = new _text_display(LM, 0, 0, 0);
Insert this directly after it...
text.paint = function (gr) {
if (!this.text_layout) return;
var h = panel.h - this.text_layout.CalcTextHeight(text.w) - 50;
_drawImage(gr, albumart.img, 20, 20, panel.w, h, image.centre);
gr.WriteTextLayout(this.text_layout, this.colour_string, this.x, this.y + _scale(12), this.w, this.ha, this.offset);
this.up_btn.paint(gr, this.default_colour);
this.down_btn.paint(gr, this.default_colour);
Reply #1060
With some modifications:
 :D
Reply #1061
@marc2k3
Many Thanks.
I needed to adjust the X axis.
_drawImage(gr, albumart.img, 0, 20, panel.w, h, image.centre);
Reply #1063
My settings:
lines 17-26
Spoiler (click to show/hide)
lines 110-115
result:
Reply #1064
Oh, I see.
Line 21: _drawImage(gr, albumart.img, 20, 20, panel.w - 40, h, image.centre);
Reply #1065
A change would need to be made for vertical alignment to work properly.
The image must translate with the text in the following way:
top image
text bottom
image center
text center
bottom image
text top.
Reply #1066
In the end I managed to find the right settings with a static image.
Now even the vertical alignment is optimal.
Reply #1067
@ApacheReal
We're just changing these values, right?
Can I change it from the context menu?
Reply #1068
@Air KEN
You can make the changes you prefer and give ok.
If they don't work, you can always reload the sample.
If they work well for you, you can export
and overwrite the Text Display + Album Art in the samples directory.
These settings are fine with a $font(Segoe UI,15)
Reply #1069
As mentioned above, for optimal use, the image must translate when the vertical alignment is changed
Reply #1070
For these modded text display scripts which always display album art not as the background, this function needs updating....
function on_playback_dynamic_info_track(type) {
if (type == 0) text.metadb_changed();
else if (type == 1 && text.properties.albumart.enabled) albumart.metadb_changed();
should now be...
else if (type == 1) albumart.metadb_changed();
But it only matters for online streams which supply album art. It can be ignored for local file playback.
Reply #1071
Is it bothersome to blur the image as a background?
The font color also changes according to the background color.
Can also be Enable Dynamic.
Reply #1072
That would be nice!
Reply #1073
Here's a quick and dirty bodge job for having album art above the text and a blurred album art background.
// ==PREPROCESSOR==
// @name "Text Display"
// @author "marc2003"
// @import "%fb2k_component_path%helpers.txt"
// @import "%fb2k_component_path%samples\js\lodash.min.js"
// @import "%fb2k_component_path%samples\js\common.js"
// @import "%fb2k_component_path%samples\js\panel.js"
// @import "%fb2k_component_path%samples\js\albumart.js"
// @import "%fb2k_component_path%samples\js\text_display.js"
// ==/PREPROCESSOR==
// https://jscript-panel.github.io/gallery/text-display/
var panel = new _panel({ custom_background : true });
albumart.blur_img = null;
var img = null;
if (panel.metadb) {
img = panel.metadb.GetAlbumArt(0);
if (this.blur_img) this.blur_img.Dispose();
this.img = this.blur_img = null;
if (img) {
this.img = img;
if (text.properties.albumart_blur.enabled) {
this.blur_img = this.img.Clone();
this.blur_img.StackBlur(60);
window.Repaint();
if (this.properties.albumart.enabled) {
_drawImage(gr, this.properties.albumart_blur.enabled ? albumart.blur_img : albumart.img, 0, 0, panel.w, panel.h, image.crop);
_drawOverlay(gr, 0, 0, panel.w, panel.h, 120);
var h = panel.h - this.text_layout.CalcTextHeight(this.w) - 50;
panel.item_focus_change();
function on_colours_changed() {
panel.colours_changed();
text.refresh(true);
function on_font_changed() {
panel.font_changed();
text.refresh(true);
function on_item_focus_change() {
if (panel.selection.value == 0 && fb.IsPlaying) return;
function on_metadb_changed() {
function on_mouse_lbtn_up(x, y) {
text.lbtn_up(x, y);
function on_mouse_move(x, y) {
text.move(x, y);
function on_mouse_rbtn_up(x, y) {
return panel.rbtn_up(x, y, text);
function on_mouse_wheel(s) {
text.wheel(s);
function on_paint(gr) {
panel.paint(gr);
text.paint(gr);
function on_playback_new_track() {
function on_playback_pause() {
text.refresh();
function on_playback_stop(reason) {
if (reason != 2) {
function on_playback_time() {
text.playback_time();
function on_playlist_items_added() {
text.refresh();
function on_playlist_items_removed() {
text.refresh();
function on_playlist_items_reordered() {
text.refresh();
function on_playlist_switch() {
on_item_focus_change();
function on_size() {
panel.size();
text.w = panel.w - (LM * 2);
text.h = panel.h;
text.size();
The right click menu options for enabling/blurring the background should work as expected. And the vertical alignment must be set to bottom as per my previous mod.
Reply #1074
// ==PREPROCESSOR==
var img = null;
if (panel.metadb) {
if (img) {
this.img = img;
if (panel.display_objects.length) {
if (panel.display_objects[0].properties.albumart_blur.enabled) {
window.Repaint();
_drawOverlay(gr, 0, 0, panel.w, panel.h, 170);
text.refresh(true);
text.refresh(true);
text.lbtn_up(x, y);
text.move(x, y);
text.wheel(s);
panel.paint(gr);
text.paint(gr);
text.refresh();
if (reason != 2) {
text.refresh();
text.refresh();
text.refresh();
panel.size();
text.h = panel.h;
text.size();
Thank you, the display looks great!
