Topic: JScript Panel (Read 315070 times) previous topic - next topic
JScript Panel
Since I can no longer make new posts, let's see if editing works??
JScript Panel
welcome to the new baby
I think you take the right decision, WSH Panel Mod will stay in v1.5.6 for those who want to run WSH panel mod scripts designed for, and new scripts will have to be for your new component.
my 3 jscripts in progress are now ported to JScript Panel:
- JS Smooth Playlist
- JS Smooth Browser
- JS Smooth Playlist Manager
I will share them as JScript Panel scripts only in next updates
The king is dead, long live the king!
JScript Panel
It's good to have you onboard.
JScript Panel
Nice. You may want to update the requirements though. You list foobar2000 v1.1 but the component requires v1.3 or above. Also, you mention clearing WSH panel properties when updating.
JScript Panel
v1.0.1
- CHG: Update default script so you know a blank panel
       is JScript Panel as opposed to WSH Panel Mod.
https://github.com/19379/foo-jscript-panel/releases
Hopefully, I removed all remaining references to WSH panel in the docs as well.
JScript Panel
I'll probably nuke the WSH repo in a few days. I'll put the last version and source in the uploads forum for anyone who wants it.
Rather stupidly, I didn't even put a description of this component in the first post so I've updated the wiki page here:
https://github.com/19379/foo-jscript-panel/wiki
JScript Panel
New JScript sample lastfm bio.txt used in chooser panel crashes. The other text samples I used (properties & thumbs) work fine. Error message below.
JScript Panel (Panel Receiver by marc2003): Microsoft JScript runtime error:
'this.content.length' is null or not an object
Line: 1, Col: 1
JScript Panel
I think it was a good idea to create a fork of WSH panel mod. Throwing away the git history prior to your fork? Not so much.
Git has some powerful tools to transplant changes from one branch to another. Re-starting history makes this process harder than needs to be because most of these tools require that the branches have a common ancestor. It does not affect me in this case so take this as a friendly suggestion instead of a complaint: Please preserve the continuity of your git history! Otherwise some day some people might form a lynch mob.
JScript Panel
One person has forked the WSH repo on github so I'm not too concerned. If they know what they're doing, they can clone the JScript Panel repo, checkout the first commit and copy those files into the WSH panel mod source folder and commit the changes.
EDIT: I just remembered github lets you download from any point in history so no need to clone/checkout the first commit. Here's the source of my very first commit to the new repo.
https://github.com/19379/foo-jscript-panel/...81db9e209a5.zip
EDIT2: Because of renamed folders, they shouldn't copy the whole zip but rather the contents of foobar2000/foo_jscript_panel/foo_jscript_panel in to foobar2000/foo_uie_wsh_panel_mod/foo_uie_wsh_panel_mod
JScript Panel
Can you add a special interface for me, that interface is used to transform metadata Traditional Chinese into Simplified Chinese?  utils.LCMapString(str,lcid,flag)
JScript Panel
If it exists in that "plus" component, I may be able to copy it. Can you give me an example of the input/output you expect so I can check it.
JScript Panel
JSSmoothPlaylist main script.txt?Line 2743-2747?2771-2773?2821-2842
A demonstration of the operation?a.pomf.cat/rtthdj.gif
Modified files?a.pomf.cat/ptlzst.7z  ?  a.pomf.cat/sztrpu.m4a
JScript Panel
v1.0.3
- CHG: Revert previous Columns UI SDK update as I've just had foobar2000 crash.
       It did actually point at Panel Stack Splitter as the problematic
       component but I've never had an issue with it before. Given PSS acts
       as a container for other panels, I think it might be related. I don't
       have the skills to troubleshoot such an issue so the easiest thing to do
       is roll back.
JScript Panel
ok switching over to JScript.
Seems there isnt an "use display preferences" selection mode on the art viewer anymore?
so I end up with same art in both Library and Now playing sides
you assisted me before with my setup with WSH panel.
https://www.hydrogenaud.io/forums/index.php...=104363&hl=
thoughts?
JScript Panel
bug report / WSH Panel Mod, method GetPlaylistFocusItemHandle no more available in plman :'(
bug in JSPlaylist that use this method...
JScript panel 1.0.3, earlier version not checked.
JScript Panel
It's my fault for not including my removal of it in the changelog. I've just updated it.
It was removed because it's identical to fb.GetFocusItem which is used much more often.
Also, I think your usage was incorrect.
var save_focus_handle = plman.GetPlaylistFocusItemHandle(p.list.playlist);
The optional argument is force which defaults to true when omitted.
Original docs:
IFbMetadbHandle GetPlaylistFocusItemHandle(force);
Original docs for GetFocusItem
    // force: if this parameter is set to false, GetFocusItem() will only look for the focus item, otherwise,
    //   if the focus item not found, find the first item of the active playlist.
    IFbMetadbHandle GetFocusItem(force = true);
You can see here where I removed it from my own mod of JSplaylist...
https://github.com/19379/jsplaylist-mod/com...08dbcede7a16f47
JScript Panel
@marc2003
It was in the "plus" component.
Forked and commit at https://github.com/smoralis/foo-jscript-pan...a96cf9ee05f626b
I hope you don't mind me contributing, this component was dead until you picked it up , so lets all contribute to make it what we all want...
@always.beta
Tested with your samples.
You need to update though your modified JSSmoothPlaylist to a JScript component compatible version.
