This layer demo draws 2 identical strings over the top of each other using the same x,y,w,h values.
The first string (black) fills the whole panel before creating a layer. The second string which is coloured is constrained with that layer.
For added silliness, I made the layer track mouse movement.
// ==PREPROCESSOR==
// @name "Layer Demo"
// @author "marc2003"
// @import "%fb2k_component_path%helpers.txt"
// ==/PREPROCESSOR==
var font = CreateFontString("Segoe UI", 24);
var mouse_x = 100;
var mouse_y = 100;
var text = 'Lorem ipsum dolor sit amet, consectetur adipiscing elit, sed do eiusmod tempor incididunt ut labore et dolore magna aliqua. Ut enim ad minim veniam, quis nostrud exercitation ullamco laboris nisi ut aliquip ex ea commodo consequat. Duis aute irure dolor in reprehenderit in voluptate velit esse cillum dolore eu fugiat nulla pariatur. Excepteur sint occaecat cupidatat non proident, sunt in culpa qui officia deserunt mollit anim id est laborum.';
// split text in to whole words for colouring
var words = text.split(' ');
var colours = [];
var start = 0;
words.forEach(function(word, i) {
// length of word plus following space
var len = word.length + 1;
colours.push({
// when using an array, Start and Length are mandatory
Start : start,
Length : len,
Colour : RGB(Math.random() * 200, Math.random() * 200, Math.random() * 200),
// increment start position for next word
start += len;
var colour_string = JSON.stringify(colours);
function on_paint(gr) {
gr.Clear(RGB(255, 255, 255));
// black text
gr.WriteText(text, font, RGB(0, 0, 0), 10, 10, window.Width - 20, window.Height - 20);
// same text coloured, constrained with small square which tracks mouse
// draw rectangle outline
gr.DrawRectangle(mouse_x - 100, mouse_y - 100, 200, 200, 1, RGB(255, 0, 0));
// create layer
gr.PushLayer(mouse_x - 100, mouse_y - 100, 200, 200);
// exact x,y,w,h values as black text but see the "layer" in effect on mouse move
gr.WriteText(text, font, colour_string, 10, 10, window.Width - 20, window.Height - 20);
gr.PopLayer();
mouse_x = x;
mouse_y = y;
window.Repaint();
