Topic: the sacd plug-in fails to load (Read 2939 times) previous topic - next topic
I have tried to install the foo_input_sacd.fb2k-component in Foobar versions 1.3.4 and 1.3.8 several times.
I always get the same error message: Failed to load DLL: foo_input_sacd.dll, Reason: Unknown error code (3221225501)
I have also tried using the foo_input_sacd-0.6.5.zip and foo_input_sacd-0.8.3.zip files with the same error.
Any suggestions? Thanks.
3221225501 = 0xC000001D (illegal instruction?)
What is your CPU?
I'm gonna guess AMD Sempron, which only supports 3DNow!Ex and SSE, but not SSE2 or newer.
Older Win XP computer with AMD Athlon -- probably no SSE2 support -- thanks.
0.8.3 really needs sse2 to work, but I succesfully used 0.6.5 (only in fixed-point mode) on Athlon XP, which also doesn't support sse2, OS was Win XP. Also 0.6.5 (and 0.6.6) loads and works (only in fixed-point mode) on virtual machine emulating pentium 3 katmai with Win XP.
