Hello hydrogenaudio!
please view this image as an example:
![](http://i.imgur.com/O8OMnHH.png)
I want to put some buttons in the top panel which will effect the contents within the navigational window.
the basic setup of my column UI config is as follows:
Panel Stack Splitter
- Panel Stack Splitter (Top)
- Panel Stack Splitter (Middle)
- Panel Stack Splitter (Bottom)
if I put some code into the top panel:
$textbutton(10,20,100,30,Library,Library,SETGLOBAL:showpanel:1;REFRESH,fontcolor:255-255-255 brushcolor:100-100-100,fontcolor:255-255-255 brushcolor:105-210-231)
$textbutton(115,20,100,30,Playlist,Playlist,SETGLOBAL:showpanel:2;REFRESH,fontcolor:255-255-255 brushcolor:100-100-100,fontcolor:255-255-255 brushcolor:105-210-231)
$ifequal($get_ps_global(showpanel),1,
$showpanel_c(A,1),
$showpanel_c(A,0))
$ifequal($get_ps_global(showpanel),2,
$showpanel_c(B,1),
$showpanel_c(B,0))
just something simple to test if it works but... it does not.
now I think this is because the code for showpanel does not look at all panels for the name "A" or "B" but instead looks at all of those underneath the splitter in which you have the code, which means that this does not work...
does anyone have any idea in how I can make this happen?
