Topic: Get Track's Top Tags from Last.fm (Read 5122 times) previous topic - next topic
I am using tags from last.fm to generate playlists.
At the moment, I am able to get last.fm tags using Picard (last.fm plus plugin).
I would prefer to just use Foobar for everything music related and stop using picard (or other apps). It makes everything simple for me.
I guess all I want is to add a function in the context menu:
"Utilities/Get Track Top Tags From Last.fm"
Then, after I click it, it saves the tags on a field of my choosing (eg. %tags_lastfm%).
How do you add this functionality in Foobar?
Or if someone has done this, can you share how it's done?
@samithaj
I forgot to post my modified version of this in the wsh discussion.
New version code below.
+ added max items for playlist
+ auto mode (get tags on playback start)
; // ==PREPROCESSOR==
// @name "Lastfm track.getInfo LASTFMTOPTAGS Tag"
// @author "zeremy"
// @feature "v1.4"
// @feature "watch-metadb"
// ==/PREPROCESSOR==
var api_key = window.GetProperty("LastFM api key", "");
var text = "";
var top_tags_values = [];
var mediafile = new RegExp("file://", "i");
var auto = window.GetProperty("Auto Mode  [on/off]", "on");
var maxitems = window.GetProperty("Max Items", "100");
var playlist_call;
function RGB(r, g, b) {
    return (0xff000000 | (r << 16) | (g << 8) | (b));
ButtonStates = {
    normal: 0,
    hover: 1,
    down: 2,
    hide: 3
var DT_TOP = 0x00000000;
var DT_CENTER = 0x00000001;
var DT_VCENTER = 0x00000004;
var DT_WORDBREAK = 0x00000010;
var DT_CALCRECT = 0x00000400;
var DT_NOPREFIX = 0x00000800;
var MF_STRING = 0x00000000;
var g_theme = window.CreateThemeManager("Button");
var g_font = gdi.Font("Tahoma", 12);
function SimpleButton(x, y, w, h, text, fonClick, state) {
    this.state = state ? state : ButtonStates.normal;
    this.x = x;
    this.y = y;
    this.w = w;
    this.h = h;
    this.text = text;
    this.fonClick = fonClick;
    this.containXY = function (x, y) {
        return (this.x <= x) && (x <= this.x + this.w) && (this.y <= y) && (y <= this.y + this.h);
    this.changeState = function (state) {
        var old = this.state;
        this.state = state;
        return old;
    this.draw = function (gr) {
        if (this.state == ButtonStates.hide) return;
        switch (this.state) {
        case ButtonStates.normal:
            g_theme.SetPartAndStateId(1, 1);
            break;
        case ButtonStates.hover:
            g_theme.SetPartAndStateId(1, 2);
            break;
        case ButtonStates.down:
            g_theme.SetPartAndStateId(1, 3);
            break;
        case ButtonStates.hide:
            return;
        g_theme.DrawThemeBackground(gr, this.x, this.y, this.w, this.h);
        gr.GdiDrawText(this.text, g_font, RGB(0, 0, 0), this.x, this.y, this.w, this.h, DT_WORDBREAK | DT_CENTER | DT_VCENTER | DT_CALCRECT | DT_NOPREFIX);
    this.onClick = function () {
        this.fonClick && this.fonClick();
function drawAllButtons(gr) {
    for (var i in $buttons) {
        $buttons[i].draw(gr);
function chooseButton(x, y) {
        if ($buttons[i].containXY(x, y) && $buttons[i].state != ButtonStates.hide) return $buttons[i];
    return null;
$buttons = {
    FindTags: new SimpleButton(5, 5, window.Width / 2 - 5, 30, "Get TopTags from Last.fm for FOCUSED ITEM", function () {
        g_metadb = fb.GetFocusItem();
        getTags();
    WriteTags: new SimpleButton(window.Width / 2, 5, window.Width / 2 - 5, 30, "Add TopTags from Last.fm to FOCUSED ITEM", function () {
        writeTags();
    WriteTagsPlaylist: new SimpleButton(5, 35, window.Width / 2 - 5, 30, "Add TopTags from Last.fm to SELECTED FILES in playlist", function () {
        writetagsplaylistselected();
    RemoveTags: new SimpleButton(window.Width / 2, 35, window.Width / 2 - 5, 30, "Remove LASTFMTOPTAGS from SELECETED ITEM(s)", function () {
        g_metadb = fb.GetSelections();
        removeTagsSelection();
    Clearoutput: new SimpleButton(5, 65, window.Width / 2 - 5, 30, "Clear Output", function () {
        text = "";
        window.Repaint();
var cur_btn = null;
var g_down = false;
function on_paint(gr) {
    myfont = gdi.Font("Segoe UI", 12, 0)
    col = utils.GetSysColor(1);
    col2 = utils.GetSysColor(0);
    gr.FillSolidRect(0, 0, window.Width, window.Height, col);
    gr.GdiDrawText(text, myfont, col2, 0, 100, window.Width, window.Height, DT_WORDBREAK | DT_CALCRECT | DT_NOPREFIX);
    drawAllButtons(gr);
function on_mouse_move(x, y) {
    var old = cur_btn;
    cur_btn = chooseButton(x, y);
    if (old == cur_btn) {
        if (g_down) return;
    } else if (g_down && cur_btn && cur_btn.state != ButtonStates.down) {
        cur_btn.changeState(ButtonStates.down);
        window.Repaint();
        return;
    old && old.changeState(ButtonStates.normal);
    cur_btn && cur_btn.changeState(ButtonStates.hover);
    window.Repaint();
function on_mouse_leave() {
    g_down = false;
    if (cur_btn) {
        cur_btn.changeState(ButtonStates.normal);
        window.Repaint();
function on_mouse_lbtn_down(x, y) {
    g_down = true;
    if (cur_btn) {
        window.Repaint();
function on_mouse_lbtn_up(x, y) {
    g_down = false;
    if (cur_btn) {
        cur_btn.onClick();
        window.Repaint();
function getTags() {
    fb.trace("-----------Get Tags---------");
    artist = fb.TitleFormat("%artist%").EvalWithMetadb(g_metadb);
    title = fb.TitleFormat("%title%").EvalWithMetadb(g_metadb);
    file = fb.TitleFormat("%path%").EvalWithMetadb(g_metadb);
    if (artist == "" || artist == "?" || title == "" || title == "?") return;
    var url = "https://ws.audioscrobbler.com/2.0/?method=track.getInfo&api_key=" + api_key + "&artist=" + encodeURIComponent(artist) + "&track=" + encodeURIComponent(title) + "&format=json";
    fb.trace(url);
    var xmlhttp = new ActiveXObject("Microsoft.XMLHTTP");
    xmlhttp.open("GET", url, true);
    xmlhttp.onreadystatechange = function () {
        if (xmlhttp.readyState == 4) {
            if (xmlhttp.status == 200) {
                try {
                    data = xmlhttp.ResponseText;
                    fb.trace(data);
                    xmlhttp.Close;
                    json_data = JSON.parse(data);
                    artist_name = json_data.track.artist.name;
                    fb.trace("Artist Name: " + artist_name);
                    title_name = json_data.track.name;
                    fb.trace("Title Name: " + title_name);
                    top_tags = json_data.track.toptags.tag;
                    items = top_tags.length;
                    if (top_tags.length > 0) {
                        for (i = 0; i < items; i++) {
                            name = json_data.track.toptags.tag[i].name.replace(/&amp;/g, " \& ");
                            top_tags_values.push(name);
                    fb.trace("Tags From Last.fm:" + top_tags_values);
                    text = "\n-----------Get Tags---------\nFile Name: " + file + "\n" + "Artist Name: " + artist_name + "\n" + "Title Name: " + title_name + "\n\n" + "Tags From Last.fm: " + top_tags_values;
                    window.Repaint();
                    if (auto == "on" || playlist_call == "yes") writeTags();
                } catch (err) {
                    fb.trace(xmlhttp.responsetext || "HTTP error: " + xmlhttp.status);
                    fb.trace(err);
                    text = "No data availiable";
                    fb.trace(text);
                    window.Repaint();
                    xmlhttp.Close;
    xmlhttp.send();
function writeTags() {
    //no data exit
    if (!top_tags_values) {
        text2 = "\n-----------Write Tags---------\nNothing to Write";
        text = text.concat(text2);
        fb.trace(text2);
        window.Repaint();
        return;
    fileinfo = g_metadb.GetFileInfo();
    lastfmtoptags = fb.TitleFormat("%lastfmtoptags%").EvalWithMetadb(g_metadb);
    //fb.trace("Tags in file:" + lastfmtoptags);
    //no tags in file write lastfmtoptags
    if (lastfmtoptags == "?") {
        //tags
        tags = top_tags_values.toString();
        tags = tags.replace(/,/g, ";");
        //write tags
        g_metadb.UpdateFileInfoSimple("LASTFMTOPTAGS", tags, "LASTFMTOPTAGS");
        text2 = "\n-----------Write Tags---------\nTags LASTFMTOPTAGS: " + tags + "\nWritten to File \n" + file;
        fb.trace(text2);
        fileinfo.Dispose();
        window.Repaint();
    } else {
        text2 = "\n-----------Write Tags---------\nTags Exist";
        fb.trace(text2);
        window.Repaint();
function removeTags() {
    fb.trace("\n-----------Remove Tags---------");
        text2 = "\n-----------Remove Tags---------\nNothing to do.";
        window.Repaint();
        return;
        window.Repaint();
    } else {
        fb.trace("Tags in file Removed:" + lastfmtoptags);
        g_metadb.UpdateFileInfoSimple("LASTFMTOPTAGS", "");
        text2 = "\n-----------Remove Tags---------\nTags Removed.";
        window.Repaint();
function removeTagsSelection() {
  var items = plman.GetPlaylistSelectedItems(plman.ActivePlaylist);
    var count = items.Count;
    if (count > maxitems) {
        fb.ShowPopupMessage("With WSH Panel Mod a separate update process is spawned for each affected file. This can lead to locking up your computer in case of too many threads with some corrupted files as a result.\n\nYour selection is larger than " + maxitems + "entries.\nReduce playlist to 100 entries.");
        return;
    for (var i = 0; i < count; i++) {
        g_metadb = items.item(i);
        removeTags();
    items.Dispose();
    text = "Finished.";
    window.Repaint();
//playlist SELECTED items get - write tags
function writetagsplaylistselected() {
    playlist_call = "yes";
    if (count > 100) {
        fb.ShowPopupMessage("With WSH Panel Mod a separate update process is spawned for each affected file. From my own experience this can lead to locking up your computer in case of too many threads with some corrupted files as a result.\n\nYour selection is larger than " + maxitems + " entries.\nReduce playlist to " + maxitems + " entries.");
        return;
        getTags();
    items.Dispose();
    playlist_call = "no";
    text = "Finished.";
    window.Repaint();
function on_playback_new_track() {
    if (fb.TitleFormat("%_path_raw%").Eval(true).match(mediafile) && (auto == "on")) {
        g_metadb = fb.GetNowPlaying();
        getTags();
function on_playback_stop() {
    text = "";
    tags = "";
    g_metadb = "";
    window.Repaint();
Thanks! I appreciate the replies.
Is there a way to quickly edit the code to use "track.getTopTags" instead of "track.getInfo"?
Also, how do we set it to automatically overwrite %LASTFMTOPTAGS% each time?
Tags are living things and changes from time to time.
I would love to do the coding myself, but I don't know how to code. So I hope this isn't asking too much.
Here you go.
+ Uses track.getTopTags.
+ Added option to overwrite. (right-click panel and in properties set to "on" or "off"
You should modify LargeFieldsConfig.txt (located in foobar2000 directory) and change defaultMetaMax to a higher value eg 5000.
# Size limit for meta fields that do not appear in either list
defaultMetaMax=5000
// ==PREPROCESSOR==
// @name "Lastfm track.getTopTags LASTFMTOPTAGS Tag (11-08-2015)"
// @author "zeremy"
// @feature "v1.4"
// In WSH panel properties (right-click panel) add your lastfm api key.
// Auto mode "ON" gets and writes LASTFMTOPTAGS on playback start.
// Overwrite mode "ON" will overwrite existing LASTFMTOPTAGS with new.
var overwrite = window.GetProperty("Overwrite Tags [on/off]", "on");
var text = "";
var playlist_call;
ButtonStates = {
    normal: 0,
    hover: 1,
    down: 2,
    hide: 3
var ww = window.Width;
var wh = window.Height;
    this.x = x;
    this.y = y;
    this.w = w;
    this.h = h;
    this.text = text;
        this.state = state;
        return old;
            break;
            break;
            break;
            return;
    return null;
$buttons = {
    FindTags: new SimpleButton(5, 5, ww / 2 - 5, 30, "Get TopTags from Last.fm for FOCUSED ITEM", function () {
        getTags();
    WriteTags: new SimpleButton(ww / 2, 5, ww / 2 - 5, 30, "Add TopTags from Last.fm to FOCUSED ITEM", function () {
        writeTags();
    WriteTagsPlaylist: new SimpleButton(5, 35, ww / 2 - 5, 30, "Add TopTags from Last.fm to SELECTED FILES in playlist", function () {
    RemoveTags: new SimpleButton(ww / 2, 35, ww / 2 - 5, 30, "Remove LASTFMTOPTAGS from SELECTED ITEM(s)", function () {
    Clearoutput: new SimpleButton(5, 65, ww / 2 - 5, 30, "Clear Output", function () {
        text = "";
        window.Repaint();
var cur_btn = null;
var g_down = false;
    gr.FillSolidRect(0, 0, ww, wh, col);
    gr.GdiDrawText(text, myfont, col2, 0, 100, ww, wh, DT_WORDBREAK | DT_CALCRECT | DT_NOPREFIX);
    drawAllButtons(gr);
    var old = cur_btn;
        if (g_down) return;
        window.Repaint();
        return;
    window.Repaint();
    g_down = false;
    if (cur_btn) {
        window.Repaint();
    g_down = true;
    if (cur_btn) {
        window.Repaint();
    g_down = false;
    if (cur_btn) {
        cur_btn.onClick();
        window.Repaint();
    var url = "https://ws.audioscrobbler.com/2.0/?method=track.getTopTags&api_key=" + api_key + "&artist=" + encodeURIComponent(artist) + "&track=" + encodeURIComponent(title) + "&format=json";
    fb.trace(url);
                try {
                    fb.trace(data);
                    xmlhttp.Close;
                    top_tags = json_data.toptags.tag;
                            name = json_data.toptags.tag[i].name.replace(/&amp;/g, " \& ");
                    text = "\n-----------Get Tags---------\nFile Name: " + file + "\n" + "Tags From Last.fm: " + top_tags_values;
                    window.Repaint();
                    if (auto == "on" || playlist_call == "yes" || overwrite == "on") writeTags();
                } catch (err) {
                    fb.trace(err);
                    fb.trace(text);
                    window.Repaint();
                    xmlhttp.Close;
    xmlhttp.send();
    //no data exit
        fb.trace(text2);
        window.Repaint();
        return;
        //tags
        //write tags
        fb.trace(text2);
        fileinfo.Dispose();
        window.Repaint();
    } else {
        fb.trace(text2);
        if (overwrite == "on") {
            removeTags();
        //write tags
        text2 = "\n-----------Write Tags---------\nOverwrite ON\nTags LASTFMTOPTAGS: " + tags + "\nWritten to File \n" + file;
        fb.trace(text2);
        fileinfo.Dispose();
        window.Repaint();
        window.Repaint();
        return;
        window.Repaint();
    } else {
        window.Repaint();
        return;
        removeTags();
    items.Dispose();
    text = "Finished.";
    window.Repaint();
    if (count > 100) {
        return;
        getTags();
    items.Dispose();
    text = "Finished.";
    window.Repaint();
        getTags();
    text = "";
    tags = "";
    g_metadb = "";
    window.Repaint();
Man, you're awesome! This is exactly what I need. Thanks again!
These are nice additions zeremy thank you very much!!!!
I think of tags the same way .Tags can be used to express what we feel about the song or some memories we have related to that song, which can be used to create quick playlists or find the song you want to listen quickly.So I add them in my local tags whenever possible.
But lastfm api has some options
Track.addTags
Album.addTags
Artist.addTags
to add them in their service , since it's very unlikely to go to song's page and add them there
it'll be very nice to do it via a script so we'll have some good, more accurate tags from lastfm
I'm trying to make a script but this academic year is not giving me much free time to work with so it's going very slowly
^those methods need authentication and the last.fm API docs are incomprehensible. if you need help with it, just give me a shout and i'll point you in the right direction.
That would be really helpful
Actually all i did was tinker this script from zeremy to add tags via input box .Your new artist recommendation script uses authentication so i guess i can use that to get api_sig ,sk parameters .I know i can use your lastfm.post to do this but no clear idea :/
