Finding duplicates and only delete duplicates in folders which contain
Reply #11 – 2015-06-24 15:37:33
Some time ago I had once tried such (the way may abilities let me do it), but there are too many possibilities, so it would end up in something like chaos. And there often are more than a single duplicate of an album, may be 3, 4...soundtracks often have very many different versions of the same movie. So I would have to eyeball very much, a very long time, I guess. Well if they are at least tagged with album titles, it should be fairly easy to eliminate them. If there are 4 duplicates you should end up with 4 hits in a library viewer, like so:Random album -- drive "E:\" folder "random album" Random album -- drive "D:\" folder "random album" Random album -- drive "D:\" folder "asdasdasd" Random album -- drive "D:\" folder "best of" The fact that the album name is shown first means alphabetically these should end up close together (even if there's any variance in the album names, generally it occurs at the end). Since they are duplicates, the second part is most likely different and easy to notice like this. Hopefully you didn't shove duplicates next to the originals with differing filenames. Obviously this isn't some magical solve all with one click method, because that doesn't exist. But it still eliminates a potentially large percentage of the problematic files fairly efficiently.Hmmm, what does that mean? To just mix them? Copy the duplicate files of version 1 to version 2? What I described at the beginning of my previous post. Assuming they are properly tagged, you can reorganize and move them into a strict filename/folder structure on the same drive, overwriting duplicates that way. This is only safe if your tags are trustworthy.But it appears there absolutely is no way to properly find / delete duplicates without extremely effort. Well, not really. Stuff is really easy to find and eliminate if they are properly tagged. If they are a mishmash of randomly tagged/named files, good luck. That's why it's so important to start tagging your library and keep it that way (new additions should take minimal effort). How many tracks do you have in your library? It will only get much worse if you neglect it now as your library grows and you still didn't get into the habit of proper organization. Fixing your library is painful, yes, but you only have to do it once, not in one sitting, and if you use the tools something like (the audio player) foobar provides, you can leverage a lot of the busywork with the smart use of it. You want to look for patterns in your library that are constant across a large number of tracks, run a batch tagging process on them, and repeat this until you are left only with tracks that are completely messed up. Track titles can usually filled using filenames, artist/album names by folder names, etc. Then at the end you can decide whether you want to fix the completely messed up ones by hand or you just never cared enough about them to keep them organized at all. Perhaps you'll find that getting rid of the junk let's you focus on and appreciate artists you actually care about more. You might also want to use a way to clearly tell apart files that have been fixed already (move them to another folder, use a dummy tag on files that are not fixed which you delete when they are, etc). As someone who went through ~40k tracks at the time, I don't think it was that bad at all as I thought it would be (I didn't type have to type in every single tag by for every single track by hand). Granted most of the files were at least decently organized into folder structures/filenames already. And I do understand that you probably have better things to do than this, but given you are already looking into tools to fix that mess, you can probably see for yourself that it will only get worse over time without organization. And the duplicate finder tools won't fix it, proper tagging will.
