Topic: Using XLD to copy FLAC files to iTunes (Read 6183 times) previous topic - next topic
This is my first post here.  I have been using XLD to rip +900 CDs onto a Synology 214+ NAS drive.  Now I find I would like to have just some of the files available to play on my iPhone, so want to copy them into iTunes in an appropriate format.  Can I use XLD to accomplish that and, if so, how do I go about it?  Thanks in advance.
You have two options, lossless and lossy.
If you want to go the lossless route the files need to be converted to ALAC (XLD lists it as 'Apple Lossless' in its dropdown). If you don't mind going down the lossy route you'd convert the original AAC ('XLD lists it as MPEG4-AAC' in it dropdown).
Both conversions would maintain meta data and a conversion to ALAC would also maintain 100% of the audio quality. Conversion to AAC could technically mean a loss of audio quality although dependent on the bitrate you probably won't notice it. I have all my backups as FLAC but only play back AAC on my portable devices and my HiFi setup. At a quality of 90 in XLD I most certainly can't hear any difference, and most likely lowering it to 75 would have the same outcome for me.
The big question at the moment is to what format you ripped your CDs. Did you rip them to FLAC, ALAC, WAV?
Every night with my star friends / We eat caviar and drink champagne
Sniffing in the VIP area / We talk about Frank Sinatra
Do you know Frank Sinatra? / He's dead
Thanks. I ripped to FLAC.  I would be fine with a quality level of 80-90 for the iTunes copy, since I will just be playing them in the gym or the car.  Can you advise how best to do that?
You ripped to FLAC, that's perfect! Just go to 'Preferences' in XLD and under 'General' you can select output format. Set that to 'MPEG-4 AAC' and click 'Option'. There I would set 'Mode' to 'True VBR', 'Encoder quality' to 'High', 'Sample Rate' to 'Auto' and 'Target quality' to '80'. Make sure 'Add gapless information for iTunes' and 'Write accurate bitrate information' are on, 'Force mono encoding' should be off. Click OK.
Back on the General tab, set 'Maximum #Threads' to the amount of logical cores your computer has. You can find this in OS X if you go to 'About this Mac', choose 'More Info' and go to 'System Report'. Under 'Hardware overview' it should say 'Total Number of Cores'. Just make sure the #Threads in XLD corresponds with that number. You can choose to have the encoded files added to iTunes straight away by ticking 'Add encoded files to iTunes if possible'.
Now you're ready to encode. You can right click on a selection of FLAC files in Finder and choose 'Open in XLD' and they will automatically by encoded to AAC files with a .m4a extension. Alternatively you could use Open from with XLD, that has the same effect.
I would advise you to convert one CD. See how that works, play the files in iTunes, on your mobile devices etc. Check if the artwork and other metadata has converted correctly. If that's all good you can convert the rest of your CDs. That's probably a job that's best to do overnight, just fill up the encoding queue, see if it's running and go to bed.
Thanks again, that seems to work . Two things:
1. XLD converts the FLAC to MP3 once, then immediately starts copying the files a second time.  Not sure why.
2.  How do I avoid ending up on my NAS (and my display on my ipad through my Auralic Aries streamer) with two copies of each album I add to iTunes?  In other words, I'd rather just create the new MP3 files in iTunes and not save a copy to my NAS, which would take up unnecessary room.
Do you have iTunes already automatically index the files on your NAS? If so, I would disable the 'Add encoded files to iTunes if possible' in XLD as iTunes already does it.
