Topic: More questions about AAC gapless (Read 7098 times) previous topic - next topic
Hello,
I want to add gapless AAC support to GStreamer. To that end, I looked into how gapless AAC is achieved. Here's where the confusion started.
I've read in various places (in this forum, and also in others like this doom9 thread) about encoder delays of 1024 and 2624 samples.
I only have ever seen 1024-sample delays with the AAC files I've tested. Curiously, there is no talk about a decoder delay. Is there none for AAC-LC?
My main questions are:
(1) How do I detect whether a file is FAAC or Nero encoded? The former uses 1024, the latter 2624 samples. From what I gathered, the name "Nero" is present inside the AAC file somewhere if it was Nero-encoded. If it wasn't, then there is simply nothing. Which means I have to always assume an encoder delay of 1024 samples unless I can detect that this AAC-LC file was encoded with Nero or iTunes (see below). Is this correct?
(2) iTunes AAC data always comes in .m4a files, correct? The m4a files (which are simply MP4 containers with one audio track) contain the iTunSMPB metadata, which in turn contain the exact delay & padding values. Are there raw/ADTS iTunes .aac files?
EDIT: typo (FLAC -> FAAC)
FLAC is an entirely different codec, not sure what you think it has to do with AAC?
Mmm... I don't really know if you need to know the codec.
I found this on a file encoded with NERO that i have:
sudta....ndrm..........Émeta......."hdlr........mdirappl.............›ilst...c----....mean....com.apple.iTunes....name....cdec.../data........ndaudio 1.3.3.0 / -br 64000 -lc...0©too...(data........Nero AAC codec / 1.3.3.0....chpl................C....ytags...]meta.......cdec......ndaudio 1.3.3.0 / -br 64000 -lc...tool......Nero AAC codec / 1.3.3.0....tseg....tshd........free
Said that, I think that you would maybe look at the source code of FAAD2. AFAIK, it was developed/extended by part of the NERO team , and I think it supports gapless decoding.
No. There are other AAC encoders, and AAC file can easily be re-muxed (using ffmpeg or something), which means that all of metadata in the container can easily be lost and you cannot rely on it.
Basically, you shouldn't assume anything, you shouldn't "detect" encoder, and you should take care of encoder delay / padding only when they are found.
iTunes doesn't directly encode into ADTS. However, you can easily remux .m4a into ADTS.
What baffles me is that Foobar can play these AAC files properly. To be exact, they are AAC-LC .m4a files, but with no iTunSMPB metadata. Looking at the decoded data in an audio editor I see the first 1024 samples are padding samples. So perhaps Foobar does assume that the first 1024 samples in AAC-LC files are always padding samples, unless the iTunSMPB metadata is found.
Maybe they use the Nero method?
