Topic: Use main_thread_callback with std::future and std::promise (Read 2363 times) previous topic - next topic
I am developing a DSP configuration dialog and I need to call "playback_control::playback_format_title" inside there. Because you can't do this outside the main thread, I have created a main_thread_callback object where I do this call.
Now I have difficulties accessing the result of "playback_format_title" in my configuration dialog again. At the moment, I use std::future and std::promise for this. But this does not work. When click the button that invokes the call and waits for the result, foobar2000 freezes. It doesn't crash, but the windows does not respond and I get a "foobar2000 does not respond anymore." message from Windows.
Here is my code:
#include <future>
struct playback_format_title_callback : main_thread_callback
public:
  virtual void callback_run() {
    titleformat_object::ptr script;
    static_api_ptr_t<titleformat_compiler>()->compile_safe_ex(script, pattern);
    static_api_ptr_t<playback_control> playback_control;
    pfc::string8 returnVal;
    if (playback_control->playback_format_title(NULL, returnVal, script, NULL, playback_control::display_level_all)) {
      promise.set_value(returnVal);
    } else {
      promise.set_value("");
  void setPattern(const pfc::string8& pat) {
    pattern = pat;
  std::future<pfc::string8> getFuture() {
    return promise.get_future();
private:
  std::promise<pfc::string8> promise;
  pfc::string8 pattern;
class CMyDSPPopup : public CDialogImpl < CMyDSPPopup > {
  void onButtonClick() {
    pfc::string8 pattern = get_pattern();
    service_ptr_t<playback_format_title_callback> cb = new service_impl_t<playback_format_title_callback>();
    cb->setPattern(pattern);
    std::future<pfc::string8> future = cb->getFuture();
    static_api_ptr_t<main_thread_callback_manager> cb_manager;
    cb_manager->add_callback(cb);
    pfc::string8 returnVal = future.get();  // <-- At this point, foobar freezes
    do_something(returnVal);
static void RunDSPConfigPopup(const dsp_preset & p_data, HWND p_parent, dsp_preset_edit_callback & p_callback) {
  CMyDSPPopup popup(p_data, p_callback);
  if (popup.DoModal(p_parent) != IDOK) p_callback.on_preset_changed(p_data);
I already double checked: promise.set_value() is    definitively executed.
Any ideas?
SDK 2015-01-15 / Visual Studio 2013 Update 4 / Whole Program Optimization turned off.
wild guess, try
std::future<pfc::string8>& getFuture() {
Using references does not change the situation - foobar still freezes.
I also tried another alternative where I initialize the promise in the dialog function:
    std::future<pfc::string8> future = promise.get_future();
    cb->setPromise(&promise);
And then in the main_thread_callback:
    promise->set_value(...);
  void setPromise(std::promise<pfc::string8> *p) {
    promise = p;
private:
  std::promise<pfc::string8> *promise;
Does not work either.
Are there other ways to get a return value out of a main_thread_callback thread?
Main thread callbacks are queued to run later, when the message pump gets around to it.
If you're in a window procedure on the main thread, you're going to wait an eternity for your callback to run.
If your call is safe to run from a window procedure, just call it immediately (and verify that you're indeed on the main thread).
If your call cannot be safely made from there, you need to queue it up and in the callback spin off whatever followup work you intended to do.
See the helpful comments in the documentation of main_thread_callback:
Allows you to queue a callback object to be called from main app thread. This is commonly used to trigger main-thread-only API calls from worker threads.\n
This can be also used from main app thread, to avoid race conditions when trying to use APIs that dispatch global callbacks from inside some other global callback, or using message loops / modal dialogs inside global callbacks.
//! Queues a callback object. This can be called from any thread, implementation ensures multithread safety. Implementation will call p_callback->callback_run() once later. To get it called repeatedly, you would need to add your callback again.
You are right, this might be the issue. I didn't think of this special case.
I think std::future and std::promise are inappropriate in this situation, so I worked out a new solution, based on function objects. And this works fine (as far as I can tell).
Here is my code:
struct query_titleformat_task : main_thread_callback
public:
      onSuccess(returnVal);
    } else {
      onFailure();
    pattern = pat;
  void setOnSuccess(std::function<void(pfc::string8)> f) {
    onSuccess = f;
  void setOnFailure(std::function<void()> f) {
    onFailure = f;
private:
  std::function<void(pfc::string8)> onSuccess;
  std::function<void()> onFailure;
  static void do_something(pfc::string8 text) {
    service_ptr_t<query_titleformat_task> cb = new service_impl_t<query_titleformat_task>();
    cb->setOnSuccess(&do_something);
    cb->setOnFailure(std::bind(&do_something, ""));
Does your do_something method do anything which you cannot do directly from the window procedure? If you have a GUI your window event handlers always run on the main thread. Unless you implement your own message loop which I consider unlikely given the problem statement in the first post.
This is not true for DSP configuration dialogs in general. If you call the dialog through foobar "View" > "DSP" menu, then it's a different thread. I already tried it. "playback_control->playback_format_title" will crash foobar if you have called the dialog through "View" > "DSP". (It does not crash however if you have called the DSP dialog through the preferences dialog.)
That's the reason why I need a main_thread_callback in the first place. My do_something procedure is fine. It just assigns the argument to a CEdit field.
Weird, I wasn't aware of that. This means your do_something method has be be careful how it communicates with the dialog.
I will have to check if I need to update my DSP tutorial.
