How do you listen to an ABX test?
The only other solution is to ALWAYS use a trusted proctor for all tests - which is what you people invoke when faced with positive results you don't agree with . No. If the person posting the positive log is not demonstrably dishonest (unlike amir and you) and does not have a strong vested interest in producing a positive result regardless of audibility AND if the audible difference is plausible (which is NOT the case if we talk about differences at 21+ kHz but the person's hearing doesn't even extend past 16k, and the used earphones also roll-off before that, and possibly even the sound card in the laptop..) then we can reasonably say: sure, there's very likely an audible difference here. If these people however even go so far as proclaiming their logs as "undeniable truth", with some of the underlying files actually being faulty, then they have disqualified themselves from any rational and honest discussion. I have explained this before, but your cognitive dissonance seems to prevent you from thinking. Your next question should also be answered with that, but since you mention QA I have to point out your hypocrisy again:Accepting claims based on biased sighted listening as long as they agree with my opinion is not a "QA mechanism", yet your business operates on it. It is a mechanism of confirming your own biases. You have nothing but claims you agree with based on your opinion. edit: corrected "unlike", thanks greynol
