Topic: Does not play a dynamic playlist (Read 1403 times) previous topic - next topic
There is a playlist with the flow. When you try to open gives an error, although Daum Pot Plaeyr plays perfectly.
Link I tried to throw http://apple.jim.stream.vmmacdn.be/hls/hls_audio_only.m3u8. When you open a playlist in Notepad seen
 # EXTM3U
# EXT-X-ALLOW-CACHE: NO
# EXT-X-VERSION: 3
# EXT-X-TARGETDURATION: 7
# EXT-X-MEDIA-SEQUENCE: 298768
# EXT-X-PROGRAM-DATE-TIME: 2015-03-15T18: 26: 36Z
#EXTINF: 6.006,
hls_audio_only_20150316T085459_298768.aac
#EXTINF: 6.006,
hls_audio_only_20150316T085505_298769.aac
#EXTINF: 6.006,
hls_audio_only_20150316T085511_298770.aac
#EXTINF: 6.006,
hls_audio_only_20150316T085517_298771.aac
#EXTINF: 6.006,
hls_audio_only_20150316T085523_298772.aac
As you can open it in Foobar2000 1.3.7?
 # EXTM3U
# EXT-X-VERSION: 3
#EXTINF: 6.006,
#EXTINF: 6.006,
#EXTINF: 6.006,
#EXTINF: 6.006,
#EXTINF: 6.006,
Sample video https://www.youtube.com/watch?v=mn233uYhOv0...Guy0JMA9-6wi6gQ
This playlist works for me in foobar2000 v1.3.8 beta 1. Did you use "Add location..." from the "File" menu to add the m3u8 playlist to foobar2000?
foobar 1.3.8b1 appears to load the playlist file with 5 entries but each one is only played for 5 seconds before it skips to the next. nothing abnormal is reported in the console.
edit: i didn't watch the youtube clip because video streaming is useless on this pc. if this is repeat information then so be it.
Okay, I see the problem now. foobar2000 does not implement special treatment for HTTP Live Streaming which this playlist uses. This is why foobar2000 treats this as a list of individual files rather than a single audio stream.
