Topic: LossyWAV help (Read 7273 times) previous topic - next topic
LossyWAV help
can someone give me a very basic way of setting this up on foonbar2000 because i have no clue on what do or what goes where. i tried using the lossywav wiki but its too technical for me to be any use.
LossyWAV help
IIRC the foo_converter.cfg I posted few months ago had personalizations for lossywav as well, download it from here and test it: http://www.hydrogenaud.io/forums/index.php...st&p=869979
Post #21 is the last version.
LossyWAV help
Open foobar2000, hold shift - File - Browse configuration folder -> put it inside the folder "configuration".
After that, right click a file -> Convert, you'll see the list.
LossyWAV help
thanks.
LossyWAV help
so far I'm still getting command errors with foonbar even with configure file i installed and even when i put the right settings in.
LossyWAV help
You need the CLI/Encoders in the \foobar2000\encoders folder. lossywav.exe? flac.exe? Which lossywav are you interested in?
Sorry I didn't touch that file for a while, for lossywav the folder must be C:\foobar2000\encoders (you can do as portable maybe another copy).
LossyWAV help
it's lossywav 1.4.0 i picked and yes i did put the encoders in the folder still didnt work.
LossyWAV help
Which LossyWAV meaning: FLAC, TAK, WV, WMALSL.
I am testing the file right now.
edit:
The configuration file was setup for D:\foobar2000\encoders not C:. Just go in the settings and change the two D: (one for lossywav.exe and one for flac.exe for example) and resave it. Everything will work.
Configuration for LossyWAV FLAC:
Encoder file: C:\Windows\System32\cmd.exe
Extension: lossy.flac
Parameters: /d /c C:\foobar2000\encoders\lossywav - --quality standard --silent --stdout|C:\foobar2000\encoders\flac - -b 512 -5 -f -o %d --ignore-chunk-sizes
Format is: Lossless (or hybrid)
BPS: 24
Encoder name: lossyWAV (FLAC)
Bitrate: empty
Settings: --quality standard | -5 --ignore-chunk-sizes
LossyWAV help
edit:
BPS: 24
Bitrate: empty
so sorry for more bad news, i tried that like more than three times still got a error.
LossyWAV help
Its unlikely you installed foobar2k where that script assumes. Change the path in it to match where foobar really is on your machine.
LossyWAV help
Forget foobar2000 for now, can you even get LossyWav by itself working at all? Are you using the latest LossyWav binary? NickC puts expiration dates on development versions that become unusable after a while.
Get a .wav file, open a command prompt and try running LossyWav on it. If even that doesn't work, then the problem is not with the foobar2000 config but lies elsewhere.
LossyWAV help
so i just installed the germanix trancoder because i just found out it has a built in lossyWAV processor. after messing about with it i finally got a lossyflac file because when open it up foonbar its bit rate is 321kbps while the original flac i made it from is 1067kbps.
