Topic: Case's Meier Crossfeed Component (Read 14696 times) previous topic - next topic
Re: Case's Meier Crossfeed Component
Reply #50
I made a 64-bit version in October last year and it can be downloaded from http://www.saunalahti.fi/~cse/temp/MeierCrossfeedVSTx64.zip. When I made it I tested it in various VST hosts and while it worked fine in others, Equalizer APO crashed if one tried to access configuration. This component relies on the host to draw the sliders it needs and it looked like EqAPO didn't support that.
Reply #51
I found out that the Peace GUI EqAPO has a MeierCrossfeed functionality.
Reply #52
You can change the Strength parameter in Equalizer APO by editing the command. Note that a space must be appended by enclosing it in double quotes because the current plugin expects it. The value is 0.1 by default and has a range of 0 to 1.
Example command
VSTPlugin: Library MeierCrossfeed.dll "Strength " 0.1
Reply #53
Hey guys, I'm new to headphones but not to hi-fi. I really like the crossfeed idea. Does Case's Meier Crossfeed tool work with Audirvana? I'm using Tidal as my source and Audirvana is the only player that works with it.
Reply #54
I just downloaded the zip file. I must be completely ignorant, I don't know how to use this. A window popped up with a bunch of code and it says at the top : This program cannot be run in DOS mode.
How do I get this plugin to work?
Reply #55
Did you download the FB2K component, or the VST plugin version? The component you should should just be able to double click and it will automatically install, for the VST version you'll need a VST plugin host such as a DAW. No need to install VST version into FB2K when there's a native component version available.
