Topic: Triple Stereo (Read 10243 times) previous topic - next topic
Triple Stereo
This plugin extracts a central component of the stereo signal and sends it to a separate channel. This makes the sound cleaner with wider panorama.
Just connect additional speaker to center channel and enjoy!
download here
Triple Stereo
Triple Stereo is crashing fb2k 1.3.7 every time I play a 24/96 and 24/192 ALAC file.
Surf's Up!
"Columnated Ruins Domino"
Triple Stereo
This is because it requires more CPU power than you have.
Triple Stereo
Do you have some kind of userguide / how to use this plugin?
Triple Stereo
Well, it is a Intel 3.10GHz, 3100 Mhz, 2 Core, 4 Logical Processors CPU. What is the minimum needed?
Surf's Up!
Triple Stereo
Drbeachboy, I don’t know, my computer is too slow for these modes too.
The first versions of my plugins can`t work in realtime – I used them only for convert. I spent many efforts to optimization with c++, assembler and second core using for make them faster as possible.
jbercx, writing userguide is a big trouble for me, because English is not my native language, sorry.
Re: Triple Stereo
Version 3.0.8 available.
- Signal decomposition now completely reverse - source channels can be restored through the addition;
- Optimized - faster at least 2 times;
- Mixing with the original stereo channels available.
Re: Triple Stereo
Final version 3.1.1 released, download now available from official repository.
Re: Triple Stereo
@ E.Sokol
The version of component is different.
Triple Stereo 3.1.0.7 (foo_dsp_TripleStereo.dll) (2022-02-04)
https://hydrogenaud.io/index.php?PHPSESSID=v9tce2geuc644cghdbl056o562&topic=108038.msg1007821#msg1007821
Triple Stereo 3.1.0.5 (foo_dsp_TripleStereo.dll) (2020-01-16)
https://www.foobar2000.org/components/view/Triple+Stereo
SHURE SRH1840, SENNHEISER HD660S2, SENNHEISER HD620S, SENNHEISER HD 490 Pro Plus, beyerdynamic DT 1990 PRO, HiFiMAN Edition XS, Bowers & Wilkins P7, FiiO FT5, 水月雨 (MOONDROP) 空鳴 - VOID, Nakamichi Elite FIVE ANC, SONY WH-ULT900N (ULT WEAR) (made a Upgrade/Balanced Cable by myself)
Re: Triple Stereo
@Air KEN, thanks for feedback. Can`t edit upload section, last buid with correct declared component version uploaded to public page.
Re: Triple Stereo
@ E.Sokol Many Thanks :)
Good component.
Triple Stereo 3.1.1 (foo_dsp_TripleStereo.dll)  (2022-02-05)
Re: Triple Stereo
Sorry, not related to the component itself but the format of update date on components page makes them not sorted correctly.
Re: Triple Stereo
Nice if we can have a 64-bit version of this component.
Re: Triple Stereo
The component requires stereo input. If you feed it anything else it will do nothing.
Re: Triple Stereo
It's playing ok now.
