Audibility of Audio Power Amplifier Distortions
Reply #29 – 2014-11-27 18:19:41
so let's see..... Yes, let's....Amir trumpets an old obscure article by Arny (his personal bete noir) & Co that seems to be comparing two amps, at least one of which had 'problems'..... Wow, how far we have come. This is a forum that prides itself on requirement for providing double blind evidence of audibility. Now posting about such evidence is a sin! Why? Because it has a positive outcome. The support for forum TOS #8 seems to have stemmed from the expectation that all double blind tests of such would result in negative outcome. I can't rationalize commentary like Steven's any other way. That aside, that test is obscure because until I bought a copy and quoted it online, no one in any of these forums had seen or read it. Even AES papers claiming to be rounding up amplifier tests did not reference this work where positive identification occurred. Hopefully with threads like this we increase its visibility and take it out of obscurity status.He admits he's never heard of or read a rather more widely read article, in Stereo Review (then a mass market newsstand magazine popular with audio fans), from 1991 by E. Brad Meyer, describing load conditions under which two amps will sound different..... Come again? You made a reference to that article. I asked you to quote what you think is relevant to this thread. You turn that into me not having the article? What does that have to do with you putting it forward as evidence? As it turns out, I do have the article . Let me quote a relevant section from it: Recall what Arny said about his testing: So the distortion level was not "well over 1%." Meyer says that shouldn't be audible failing to know about Arny and Crew's listening test 9 years prior disputing the same.All the while, across multiple websites and threads therein he makes of habit of putting people down* in the guise of 'educating' them from his expert** POV... And then complains here that posts critical of him have the intent of 'putting me down under the cover of giving me advice'.... Is this guy a piece of work, or what? Once more I am going to request that members stay focused on the technical topic and not discuss me personally. Right now you are in the hot seat Steven. You referenced an article you are quoting. Claimed i don't have a copy of the article which I clearly do. I have quoted a section from it that disputes your notion that there is nothing new in Arny and friend's test. Arny's test showed audibility at 1% distortion and Meyer says that is not supposed to be audible. You have an answer for this?
