Topic: 0.7 Public Test (Read 216303 times) previous topic - next topic
0.7 Public Test
beta8 posted
0.7 Public Test
Not a real bug, more an annoyance introduced in 0.7: When balloon tooltips are enabled (on Windows XP) it gives the System Notification sound whenever a tooltip appears. In other words, every song starts with an annoying *plop* sound
In foobar 0.6 there was no sound at all. I liked that a lot better
[fixed in beta9 with NT-only utf8api.dll]
Oh, and the Window size isn't saved... (beta 8)
0.7 Public Test
Beta 9 is up now.
0.7 Public Test
Beta 9 reuploaded with balloon tooltip sound hotfixed.
0.7 Public Test
Nadda, still plays the sound..
edit: BTW, running Windows XP.
0.7 Public Test
http://foobar2000.org/utf8api.dll - winnt-only - should fix issues with sound played when balloon popup shows up, for real this time (note to self: stop trying to fix code when you're not awake).
0.7 Public Test
Yep, that fixed it! Thanks
Windows size and windows position are still not saved on restart of foobar2000.
0.7 Public Test
Reply #32
Installers updated with now fixed utf8api. People missing extra components like Burninator might enjoy big installer.
0.7 Public Test
Can't reproduce. Please check your settings instead of reporting the same "bug" over and over.
0.7 Public Test
Reply #34
Oops, I just noticed the "Remember Window Positions" checkbox in the preferences (thanks Ryan  ). Sorry for bothering you with this stupid thing.
0.7 Public Test
Reply #35
When playing such Cue files
the first track will be skipped and the last second track will be missing.
But it worked well in 0.6xx version.
PERFORMER "Soundtrack"
TITLE "The Legend of 1900"
FILE "G:\Lgend 1900\01 1900's Theme.ape" APE
  TRACK 01 AUDIO
    TITLE "1900's Theme"
    INDEX 01 00:00:00
FILE "G:\Lgend 1900\02 The Legend of the Pianist.ape" APE
  TRACK 02 AUDIO
    TITLE "The Legend of the Pianist"
    INDEX 01 00:00:00
FILE "G:\Lgend 1900\03 The Crisis.ape" APE
  TRACK 03 AUDIO
    TITLE "The Crisis"
    INDEX 01 00:00:00
FILE "G:\Lgend 1900\04 The Crave.ape" APE
  TRACK 04 AUDIO
    TITLE "The Crave"
    INDEX 01 00:00:00
FILE "G:\Lgend 1900\05 A Goodbye to Friends.ape" APE
  TRACK 05 AUDIO
    TITLE "A Goodbye to Friends"
    INDEX 01 00:00:00
FILE "G:\Lgend 1900\06 Study for Three Hands.ape" APE
  TRACK 06 AUDIO
    TITLE "Study for Three Hands"
    INDEX 01 00:00:00
FILE "G:\Lgend 1900\07 Playing Love.ape" APE
  TRACK 07 AUDIO
    TITLE "Playing Love"
    INDEX 01 00:00:00
FILE "G:\Lgend 1900\08 A Mozart Reincarnated.ape" APE
  TRACK 08 AUDIO
    TITLE "A Mozart Reincarnated"
    INDEX 01 00:00:00
FILE "G:\Lgend 1900\09 Child.ape" APE
  TRACK 09 AUDIO
    TITLE "Child"
    INDEX 01 00:00:00
FILE "G:\Lgend 1900\10 1900's Madness #1.ape" APE
  TRACK 10 AUDIO
    TITLE "1900's Madness #1"
    INDEX 01 00:00:00
FILE "G:\Lgend 1900\11 Danny's Blues.ape" APE
  TRACK 11 AUDIO
    TITLE "Danny's Blues"
    INDEX 01 00:00:00
FILE "G:\Lgend 1900\12 Second Crisis.ape" APE
  TRACK 12 AUDIO
    TITLE "Second Crisis"
    INDEX 01 00:00:00
FILE "G:\Lgend 1900\13 Peacherine Rag.ape" APE
  TRACK 13 AUDIO
    TITLE "Peacherine Rag"
    INDEX 01 00:00:00
FILE "G:\Lgend 1900\14 Nocturne with No Moon.ape" APE
  TRACK 14 AUDIO
    TITLE "Nocturne with No Moon"
    INDEX 01 00:00:00
FILE "G:\Lgend 1900\15 Before the End.ape" APE
  TRACK 15 AUDIO
    TITLE "Before the End"
    INDEX 01 00:00:00
FILE "G:\Lgend 1900\16 Playing Love.ape" APE
  TRACK 16 AUDIO
    INDEX 01 00:00:00
FILE "G:\Lgend 1900\17 I Can and Then.ape" APE
  TRACK 17 AUDIO
    TITLE "I Can and Then"
    INDEX 01 00:00:00
FILE "G:\Lgend 1900\18 1900's Madness #2.ape" APE
  TRACK 18 AUDIO
    TITLE "1900's Madness #2"
    INDEX 01 00:00:00
FILE "G:\Lgend 1900\19 Silent Goodbye.ape" APE
  TRACK 19 AUDIO
    TITLE "Silent Goodbye"
    INDEX 01 00:00:00
FILE "G:\Lgend 1900\20 Ships and Snow.ape" APE
  TRACK 20 AUDIO
    TITLE "Ships and Snow"
    INDEX 01 00:00:00
FILE "G:\Lgend 1900\21 Lost Boys Calling.ape" APE
  TRACK 21 AUDIO
    TITLE "Lost Boys Calling"
    INDEX 01 00:00:00
0.7 Public Test
Reply #36
- dsp "move stereo to rear channel" use 5% time processor of my duron 1.1 ghz, compare to 3% eq, 1% advanced limiter. problem of terratec DMX 6fire driver ?
It may be worth noting that this also forces 4ch output instead of 2ch.
0.7 Public Test
Reply #37
0.7 beta 9 won't load any pls playlists, no problems with fpl playlists or with 0.667 version with same playlist files.
0.7 Public Test
Reply #38
This modified foo_input_std should fix it.
0.7 Public Test
Reply #39
Playlist search bug: caracters as "é" "ö" aren't recognized.
No problem with 0.667
edit: windows 98 , foobar 0.7b9
Music is my first love.
0.7 Public Test
Reply #40
I'm using 0.7b9 and Windows XP.
When i press "right" or "left" to seek in the song foobar crashes.
0.7 Public Test
Reply #41
Esoteric bug/behavior (not important, but it's there):
Using [Show File Info] on a now playing item and editing one of the tags puts the file in queue to be updated which usually works perfectly, if however after the file is queued I use Masstagger on all files to change some other tag the queue is emptied and the file isn't updated.
0.7 Public Test
Reply #42
foobar2000 v.7 b9 fails to start when run with limited user privilages. Here's the information from the event log.
Application popup: foobar2000.exe - Application Error : The application failed to initialize properly (0xc0000022). Click on OK to terminate the application.
Additional info:
Windows XP Professional SP1
User profile support is enabled
Previous versions ran fine with limited user privilages
0.7 Public Test
Reply #43
cue sheets don't work with 0.7b9
doesn't find some files, doesn't play the files that are displayed
same cue sheets works perfect with 0.667
0.7 Public Test
Reply #44
Someone already reported cue problems and I posted link to modified standard inputs. This should solve all cue issues and be even compatible with EAC's non-compliant cues.
0.7 Public Test
Reply #45
Can't reproduce, please post a sample playlist.
0.7 Public Test
Reply #46
Can't reproduce.
0.7 Public Test
Reply #47
Additional info:
Can't reproduce.
0.7 Public Test
Reply #48
Can't reproduce. Do you run masstagger while still playing ?
0.7 Public Test
Reply #49
Yep, I do. I tried it again:
1. play song
2. edit some tag in it - (it's queued now)
3. masstag all the songs (change some other value) the original is still playing
4. I stop the playing song, it's updated, but if I let it play till the end, it's not updated (neither of the tags, not the masstagged one nor the edited one); after the song finished playing I used [reload info from file].
I don't use db.
