Topic: Audibility of "typical" Digital Filters in a Hi-Fi Playback  (Read 331204 times) previous topic - next topic
Reply #325
The stiffness of the tweeter cone helps determine how pure and uncoloured the sound is at high frequencies. Beryllium is many times stiffer than aluminium, the material usually used in tweeter cones. Being stiffer, the dome acts as a more perfect piston – delivering more accurate transients and lower colouration. In addition, its extended high frequency response is ideal for getting the best out of today’s high-resolution recordings.
This stiffness is the problem. Some years back all extreme hard domes had a resonance. Unfortunately i can't find a neutral measurement of these 7200SE
Reply #326
Imagine BS just released the most comprehensive paper ever published about audibility of IM in typical metal dome tweeters
Reply #327
I hear you.  Ultimately the paper does document the performance of that speaker and it shows no on-axis resonance in semi-anechoic measurements.
AJ's hypothesis hinges on off-axis resonance.  What's our theory of that surviving the room absorption by fair bit?
Amir
Retired Technology Insider
Founder, AudioScienceReview.com
Reply #328
I don't want to present speculation as fact, but if there is a measurable resonance, that indicates the presence of a real mechanical property that would usually have wide-ranging implications. These could be somewhat (but not completely) ameliorated by making the on-axis response "flat" using DSP. (A gifted designer might be able to achieve a similar effect mechanically, damping the resonance sufficiently on axis, but leaving traces off axis.) The effect of the resonance may still be detectable off axis, and/or in certain time domain measurements, and/or in certain distortion measurements. The result of IMD (for example 24+26kHz), being at a much lower frequency, may have a different polar response, and in any case has no trouble bouncing off the walls.
I have no idea of the facts or reality of the situation, but we don't know nearly enough to discount this. It would be foolish to claim that this particular effect must be audible, but it would be almost as foolish to claim that it must not be.
Chance would give you 50% correct. The overall results were 56% correct. Whatever effect we're looking for here is a very small one.
David.
Reply #329
Just commenting on this part, my read of this number is that it was the threshold of 95% confidence interval, not the actual outcome.  Here is the graphics again:
Amir
Reply #330
Absence of data is not data David.  It is not logical to say that we don't know if you are or are not a bank thief and have it create the impression that you might be.
As I quoted, the authors are very well aware of previous test of this nature that was potentially invalidated due to ultrasonic intermodulation distortion.  It would be really odd to note this and then go on to make the same mistake.  Should this turn out to be a repeat of the same issue, it would reflect very poorly on the authors/work.
The real measurements are posted for on-axis and do not show this type of resonance or at least not an extreme one.  So the prima facie evidence is that our guess of extreme resonance here is not supported.
On off-axis where no measurement is provided (although some of it is included in the semi-anechoic measurement), I ask again: how does that survive at nearly 30 Khz in room?  Absorption of such short wavelengths will be quite high and very different than sticking a mic right in front of the driver in anechoic chamber.
I want to be clear: I am not defending the performance of Meridian speakers.  I am just saying if this is all we can hang our hat on, it is weak argument given the data we have (or more correctly, don't have).
Amir
Reply #331
What do you think the 56% represents?
Please try not to sprain your wrists; they already look a little swollen.
Re: Regardless of whatever they didn't address, we must assume it was done correctly.
I see you're misplacing the burden of proof, yet again.
So much for being in the objective camp.
Reply #332
I explained that already.
Come again?  We have a double blind study showing with high confidence there are differences.  The burden of proof that it is not valid lies on shoulder's people who just want to throw guesses out there and see what sticks.  And do so with extreme prejudice.  I am calling them on their lack of supporting evidence.
Same to you mister.    When will you start to act objectively?  There is a report in front of us.  You can't only focus on negative hypothesis, and say you are being objective.
I am not telling you this report is definitive.  I am saying that we relied on hobby work before (Meyer and Moran) and now we have a much more proper test.  The report has won an award backing my impression of it being good work.  This is the objective view.  The notion that the test must be wrong is the non objective view.The notion that Meyer and Moran was the definitive truth was the non objective view.
So please don't lecture me on what is objective.  I know what it is and it has nothing to do with what you all do in these forums where emotions and prejudice rule ahead of knowledge.  Just look at the first two pages of this thread.  So there.  We are even.
Edit: typos.
Amir
Reply #333
Eye-balling that plot suggests the overall arithmetic mean was about 62% correct then - is that how you interpret it?
That's still a small effect.
FWIW I can remember of a couple of ABX tests here on HA that have gone to that level (running over 100 tests to hit statistical significance), but I bet I'm not the only one who has ABXed differences so small I thought I might be imagining them, yet passed an ABX test much more easily than this. Hence in my mind (rather than mathematically) I can't begin to grasp how small this difference must be.
It's a strange thing to launch a new product on, isn't it? Doesn't the commercial world usually go for bigger wins? 2x or 4x subjective improvements to launch a new format? AM to FM. VHS to DVD. SD to HD. I don't recall a 15 wait before someone finally managed to spot the improvement in a double-blind test with those. I know we're not talking about physical formats any more, but still; the commercial realities of what people will pay to replace/upgrade must still apply. Maybe in 2-channel audio formats there isn't a 2x or 4x improvement left.
Don't you think it's strange that you do so much better with your laptop and headphones on whatever sample someone throws at you than the inventors of MLP did when they got to pick the sample, conversion settings, speakers and listeners? Did your work at Microsoft reveal you had sensitive hearing right from the start, or did your ability to hear artefacts improve with training and exposure to them during that time, or did it happen since?
David.
Reply #335
You are wrong in the specific here but let's put that aside.  You say that I don't know this fact.  Well, read this article I wrote on WBF Forum with respect to relationship of Time vs Frequency in acoustic measurements.
Whooosh.
This is way over your loudspeaker hobbyist/non-professional head Amir. You implied the paper showed relevant loudspeaker data, it does not (save for the FR extension).
It shows the same useless thing twice! Your (WTF? forum) obfuscation can't help there.
Completely absent is the distortion data for the tweeter, showing whether the >22k resonance creates artifacts within the audio band, when driven to 105+ db, with and without 22k band limiting. Or not.
Which in this case is something to be verified!
BINGO!! Yes, this possible artifact generating confounder is completely absent in the BS paper. Your side better address it.
Remember we don't have anything remotely like that from Meyer and Moran.
Remember, that's a complete Red Herring to the BS paper. Even if you can't be cognizant of it, due to lack of basic  comprehension of logic.
In other words, this is pure speculation.  You don't even know if this is the tweeter they used.  You don't know if it is that it generates IM distortion in-band.
Correct, because it is clumsily absent from your BS paper. Zero data on speaker transparency to the test goal. You really should pay heed to JJ's warnings about possible artifacts creating false positives in these type tests, even if you have no understanding of them.
Once again, the burden of proof is not on me to "prove" the BS system is free of audible artifacts, speaker, software or otherwise.
Your theory is that with full knowledge of issues surround intermodulation, they entered the test blind and fell victim to it anyway?
Nope. Not my theory.
cheers,
AJ
Loudspeaker manufacturer
Reply #336
Bzzzt, whoosh.
It's not the "off axis" >22khz FR that might, or might not be audible. Room absorption has ZERO to do with this.
cheers,
AJ
Reply #337
If the SEAS is confirmed as the tweeter in the 7200SE (Meridian forum give hints), there are measurements.
**However**, rational people generally don't perform the specific measurement we need.
When high end manufacturers 1" DR beryllium domes (Scan-Speak in this case) already exhibit significant deviation from linearity by 95db
Most won't press to 105db, probably from fear of damage/destroying them.
Also, I highly doubt they would do so with test signals with strong ultrasonic content (like the cherry picked recording).
Btw, isn't it curious that no direct downsampled to 16/44 WAV (CD) is available on the 2L site for direct (Hi Rez vs CD) comparison to the "Hi Rez" versions. (Only a FLAC version, which adds another confounder).
Hmmm.
cheers,
AJ
Reply #338
The launch of both SACD and DVD-A were due to business needs, not consumer.
SACD came about because the CD patents were about to expire and Philips and Sony needed another proprietary format so they came up with SACD.  The format also came out when piracy was seen as a major threat to music labels.  So they wrote in their license that you could not even play SACD on a PC let alone rip it!  They wanted to "unring the bell" with CD's lack of copy protection.
DVD-A came about because the rest of the CE industry couldn't see another gravy train for Sony/Philips.  They had created the DVD standard in DVD Forum (and Audio DVD) so they pushed ahead with a complex and messy system requiring interpreting fancy menus and such.  This made building players difficult and very expensive due to high royalties that the fancy menu people demanded.  And of course they put in a strong copy protection because DVD was breached and due to piracy factor above, they would have no hope of getting content if they did not rise up to SACD's level of copy protection.
You say that the quality difference was incremental/tiny.  Not at all.  Music that we remastered for these formats sounded far better than the CD.  You can read this in Meyer and Moran report:
Though our tests failed to substantiate the claimed advantages of high-resolution encoding for two-channel audio, one trend became obvious very quickly and held up throughout our testing: virtually all of the SACD and DVD-A recordings sounded better than most CDs—sometimes much better. Had we not “degraded” the sound to CD quality and blind-tested for audible differences, we would have been tempted to ascribe this sonic superiority to the recording processes used to make them.
Plausible reasons for the remarkable sound quality of these recordings emerged in discussions with some of the engineers currently working on such projects. This portion of the business is a niche market in which the end users are preselected, both for their aural acuity and for their willingness to buy expensive equipment, set it up correctly, and listen carefully in a low-noise environment.
Partly because these recordings have not captured a large portion of the consumer market for music, engineers and producers are being given the freedom to produce recordings that sound as good as they can make them, without having to compress or equalize the signal to suit lesser systems and casual listening conditions. These recordings seem to have been made with great care and manifest affection, by engineers trying to please themselves and their peers. They sound like it, label after label. High-resolution audio discs do not have the overwhelming majority of the program material crammed into the top 20 (or even 10) dB of the available dynamic range, as so many CDs today do."
So the quality differential was absolutely there.  If not in specs, but actual performance.
Why did they fail?  Simple: general consumer puts convenience ahead of fidelity.  With MP3s they were getting huge convenience over CDs.  Many songs in your pocket.  And here come these labels and CE companies saying, "here is a new disc and oh, you can't rip it and we are proud of it!"  The tiny group of audiophiles who cared about the difference could not save one format let alone two in the midst of a format war.
So both failed and the record execs who claimed this was their savior fired.
Fortunately we are able to take a second bite out of the apple now.  By downloading high resolution content and ease with which we can play them, there is no longer a technological barrier.  Most wonderfully, the files are copy protection free allowing full portability.  This is why the formats are growing despite catastrophic failure before.  Everything about them is different this time around.
Edit: typos as usual .
Amir
Reply #340
??? Here is the measurements of the track in question:
Amir
Reply #341
Some may find it ronic that that soft domes can perform far better than hard domes.
This is the FR of the DSP7200 from the paper:
Larger version in this post: http://www.hydrogenaud.io/forums/index.php...ost&id=8070
Ironically, I have 2 Primus PC351 with their hard dome tweeters replaced with Vifa soft dome tweeters that have similar response up to the 40 KHz limit shown here.  The hard domes had the expected resonance and roll off following it.
Reply #342
Where do you see 105 db of ultrasonic dynamic range AJ?
Bzzzt. Those aren't the droid we're looking for.
At some point, you may or may not figure out why why need to see system transparency (speakers, software, etc) data to avoid the possibility of false positives due to artifacts.
Take your time amir, we'll wait for you.
I asked them why they did that and the answer was: "to make the dude in florida angry" except they used the Nordic term for "dude."  Honest!
It's not the 2L folks that have me wondering why that track was picked amir.
Now, before wee get further, perhaps some tidbits directly copied from the "award winning" BS paper:
This Convention paper was selected based on a submitted abstract and 750-word precis that have been peer reviewed by at least two qualified anonymous reviewers. The complete manuscript was not peer reviewed. This convention paper has been reproduced from the author's advance manuscript without editing, corrections, or consideration by the Review Board. The AES takes no responsibility for the contents.
It should be noted that, although the FIR filters were comparable to those used in converters or mastering, the downsampling to 44.1 kHz or 48 kHz was not carried out; it was not feasible to replicate an A/D or D/A converter exactly since they typically use multi-stage decimation. We wanted to emulate the frequency and impulse responses of such converters while remaining in the 192 kHz domain.
The quantization either included RPDF (rectangular probability density function) dither or did not. We chose to use undithered quantization as a probe and although we would normally recommend TPDF dither for best practice we considered rectangular dither to be more representative of the non-ideal dither or error-feedback processing found in some commercial A/D and D/A filters.
CONCLUSIONS
1. FIR filters that emulate downsampling for sample rates of 44.1 kHz and 48 kHz can have a deleterious effect on the listening experience in a wideband playback system.
2. 16-bit quantization with and without RPDF dither can have a deleterious effect on the listening experience in a wideband playback system.
Seems like a tempest in a teapot rather than anything revelatory.
cheers,
AJ
Reply #343
Don't you think it's strange that you do so much better with your laptop and headphones on whatever sample someone throws at you than the inventors of MLP did when they got to pick the sample, conversion settings, speakers and listeners? ...  Cheers, David.
  Keep in mind Amirm isn't using just any old headphones; the Etymotic ER4 series effectively gives the listener a state-of-the-art, soundproof room to listen in, quite possibly even better than the special room Stuart et al. actually used, so hearing faint residual noise in the recordings, including the recordings' noise floors, over one's environmental ambient noise [which acts as a masker] is a much easier task (without any need for the use of elevated gain) especially apparent during the musical lulls and fadeouts.
The ER4 series [green curve] suppress environmental room noise where the ear is most sensitive so well that it is literally "off the charts" even when using the expanded scale range seen below. [As reference I've selected a more typical audiophile design, the Sennheiser 800 [blue], and Bose ACTIVE Noise Canceling headphones QC15 [red] for comparison]:
I own several Etymotic earphones as well, they were given to me by the manufacturer, but I rarely use them mostly due to comfort issues. Similar to standing in a UBER expensive anechoic chamber, under quiet conditions when there is no nearby traffic or HVAC noise to contend with, late at night, I can hear my own heart beat through "bone conduction" when wearing them (in the absence of music). It's impressive.
Reply #344
So you don't want to answer the question.  I will. There was no 105 db tone hitting the tweeter at 30 Khz.  The music signal is down to 20 db SPL at that frequency.  Any intermodulation would be at far lower level.
If such low level distortions are audible, that gives away the farm more than anything in this report.  You would be saying that sub-zero db SPL distortions are not masked and are audible in double blind tests.  Is that where you want to go AJ?
Amir
Reply #345
This is a hilarious step, even for you, DM.
The *mastering* difference was *sometimes* great and therefore obvious (sometimes it was WORSE).  That same great and therefore obvious quality could have been achieved on a CD, had the producers and mastering engineers so chosen.
THAT was M&M 's point.  That great and obvious difference did not require >44kHz sampling or >16 bits  in the delivery medium, to achieve.
The  'high resolution delivery format' was immaterial,  except  in the sense that it sometimes 'obligated' (but did not force) the producers to provide a proper 'audiophile quality' mastering....which was then used to *falsely  'demonstrate' the overblown claims for the HR format itself, to uninformed listeners* --like the ones who buy fancy DACs from you, thinking they will hear 'night and day' difference.
Reply #346
No, I started up pretty "deaf."  I remember being shocked that I could not hear much difference between 128 kbps MP3 and the source.  That bothered me .  So I started on a path to become a trained listener and after literally hundreds of hours of testing, and tons of education learning about psychoacoustics and algorithms in audio processing, all of a sudden found myself in a super unique situation of outperforming everyone else around me in such tests.  I have never liked the phrase but everyone would call me the "golden ear."
The experience taught me to use my ears as an instrument and separate it from enjoyment of music.  Today I can't let go of that skill.  It seems to be with me forever.  For that reason US DBS broadcasting (eg. XM) bothers me to no end.  I love the content but can't listen to it.
And let's distinguish between hearing and listening.  My hearing is shot due to age.  I am embarrassed to say that I can't even hear 12 Khz well.  The reason I do well still I think is that I focus on what I think technically matter and combine that with my training to look for small differences.  I suspect people with my training but intact frequency response will be able to do a lot better.  I actually ran into one such person at Microsoft who was working with a partner of ours.  He was hearing high frequency distortions I could not.  We hired him immediately .  And I moved off from doing a lot of the listening tests myself.
Let me confess.  I had no idea I could do this after so many years after retirement.  I just ran the tests because people like Arny kept egging me on so I gave it a try.
Having read the Stuart paper and prior citations, I am starting to think this may be due to time domain impact.  It certainly is not frequency domain since I can't hear the ultrasonics. Just as pre-echo is a very audible time domain artifact (although created in frequency domain), maybe these filters act the same way.
Amir
Reply #347
It did from business point of view.  What enabled labels to dump millions of dollars into new masters was the advent of new formats with strong copy protection.  If you stayed with the CD you wouldn't get it.
Well, you seem to be lost as to what argument we are having.
Amir
Reply #348
Good lord, this is a weak and weasely argument, even for you.  Hi rez is not marketed as 'better copy protected!'  No one reviews the copy protection of hi rez releases.  Its not what you and your ilk rave about.
Here's the facts:
Sub-audiophile mastering was not a development *necessitated* by the CD format. (It's actually a perversion of the original intent of CD)
And you didn't *necessarily* avoid it with 'hi rez' either.  I have hi rez releases that are as 'smashed' as their 'modern remastered' CD counterparts.  TAKE A LOOK
So even you can see, surely, how mendacious it is to ascribe 'better sound' to the *hi rez format* ?  That's what magicians call *misdirection*.
The fact is, we play the odds when be buy music.  The odds of getting an audiophile mastering might be *better* for 'hi rez' but it's  still a gamble, and it still just shows how contemptuous the industry is of us --  when the same mastering could be offered on CD or 16/44 download, for less $$.
We are *talking about*, at root, the overblown claims for hi rez audibility that have accompanied it since at least the late 1990s.  The sequence of reports since then about hi rez sound from Stuart, from Oohashi et al, Meyer & Moran, from Monty, and everyone in between, have *all* been about that, in essence.
*You* don't get to dictate what *my* thread is about, Dancing Man.
Reply #349
I tried to make this point earlier.
