Topic: Streaming to Marantz M-CR610 (Read 2583 times) previous topic - next topic
Hi, im new to foobar and just finding my feet with the application, in the next few weeks im thinking of buying the Marantz M-CR610 for its streaming capabilities.
I was just wondering which plug-in is available to stream from the PC to the system? Once set up will this let me use foobar alone to stream my music files?
This one "sends": http://www.foobar2000.org/components/view/foo_out_upnp
This one acts as a server: http://www.foobar2000.org/components/view/foo_upnp
I don't know if you can browse UPnP devices with that Marantz but the first component should work since the M-CR610 is DNLA capable.
...it's AirPlay too so even this component will work: http://emilles.dyndns.org/software/out_apx.html
Thanks, that's great, probably take me a while to get up to speed with using foobar, and streaming as I haven't really had enough experience with either.
Cheers!
I have an older Marantz: the M-CR 603.
The Foobar plug-in "foo_upnp" mentioned by eahm does indeed work with my Marantz, allowing me to browse the contents of my music library either by folder structure, or by album, artist etc. I would imagine it will work just as well with the newer Marantz you are considering; as far as I am aware, the M-CR 610 does everything the 603 does and more.
Bluto
