Topic: is there a lame mp3 plugin for autidion cc? (Read 4300 times) previous topic - next topic
hi
i use audition cc and i'm looking for an lame plugin
i found the wavepack plugin  called AmioWavpack.amio , it's enough to copy in the plugin audtion cc plugin folder
do you know if there is lame plugin?
thanks
hi
thanks
Try https://www.google.com/search?hl=en&sou...0.0.oitxuwW1ERg
Maybe third search result will satisfy you.
i search before ask about an audition cc pluing
the third result is about lynda , and rarewares but the plugin it 's the older versions
thanks
Yes, filter is old, but at first try, then criticize or ask once again for help.
From rarewares.org:
CoolLAME Filter
2007-01-19
Filter for Cool Edit and Adobe Audition that uses lame_enc.dll for MP3 encoding
Following link you can download the latest available lame_enc.dll
From rarewares.org:
CoolLAME Filter
2007-01-19
thanks adamjk
but the first thing i did , was tried it
but cc doesn't accept anymore flt filters they are not more compatible
i will try to make LAME DirectShow Filter work
it could be a solution , i installed but don't know why audition cc doesn't detect it
maybe i did something wrong or because it's 32bit
Re: is there a lame mp3 plugin for autidion cc?
From rarewares.org:
CoolLAME Filter
2007-01-19
thanks adamjk
Ask for .AMIO plugin here:
https://www.voukoder.org/forum/thread/532-poll-what-program-you-d-like-to-have-a-connector-for/?pageNo=3
