Quality of Sony's 1-Bit High Density Linear Converter?
Reply #6 – 2014-09-09 23:01:03
... I'm curious about the quality of the 1-bit pulse DAC (High Density Linear Converter).... Is it in the cheap/crappy range? is an improvement over first generations of DACs? I know there are different types of DAC, is 1-bit DAC better or worse than the others. ... The following history of DAC development is greatly simplified. The first DACs were NOS (Non OverSampling). They fed the digital values for each sample to a series of switches which allowed current to flow through a network of precision resistors. The sum of the currents equalled the analogue value represented by the sample. The disadvantage of this was that for 16 bits the switches and resistors had to be very high precision, and this was expensive to manufacture. Also, the output reconstruction filter had to be high quality (and expensive). Single bit DACs had just one switch and resistor. For each sample, the switch triggered for a number of times corresponding to the digital value. The sum of the current pulses corresponded to the analogue value for that sample. This is a form of sigma-delta conversion. While it made the hardware cheaper, it proved difficult to stabilise the pulse generator to produce a low distortion, low noise output. Because of the limitations of single-bit conversion, manufacturers compromised. Modern DACs use a combination of NOS and sigma-delta technologies. Typically, 4 or 5 of the bits are decoded "directly". The tolerances required for this number of bits are manageable. The rest of the bits are decoded using the pulse generator scheme. This relaxes the requirements on the sigma-delta stage and makes it easier to linearise. So in theory, a modern multi-bit sigma-delta DAC will outperform the one in your Sony. But the performance of the chip is only one part of it. The rest of the circuitry around it has to be well designed and implemented. If care was taken in the design and construction of your Sony player, it may well outperform a poorly designed modern player. So if it works well and you're happy with the sound, carry on.
