Topic: Free software for setting cue points in WMA files? (Read 5871 times) previous topic - next topic
Anyone know a free Windows program allowing setting of cue points in WMA files?
I don't know why this post has been moved to this Lossy Audio Compression forum.
FTR, the WMA format in use is lossless.
Hmm... dunno if WMA is supported but ...
if you have CD's ripped as lossless WMA you could try by editing the album .CUE file (get it from http://www.regeert.nl/cuesheet/ or use CueMaster -tool) so that the FILE parameter points to your .WMA file and the type is WAVE.
Example:
orig. FILE "Emmylou Harris - All I Intended To Be.mp3" MP3
mod. FILE "Emmylou Harris - All I Intended To Be.wma" WAVE
If WMA is supported then ...
if your WMA files are your own recordings (from vinyl etc.) then you probably need to convert those back to wav before you can add those cue markers. With vinyl rips you can use the CD cue file as base data but usually you need to adjust the INDEX 01 values manually.
Hmm... if you have CD ripped as lossless WMA you could try by editing the album .CUE file
Thanks, but these are not from CD and have no CUE.
If your WMA files are your own recordings (from vinyl etc.) then you probably need to convert those back to wav before you can add those cue markers.
Using GoldWave I can add them without converting. Just that I need a free program for other users.
