Topic: Lame 3.99.5 Intel Lib Compile (Read 16263 times) previous topic - next topic
my intel build
http://www.mediafire.com/download/n31ij9qd...intel_win32.zip
intel 10.1 & MSVC 2008 Express + libc.lib (libirc.lib v9.1) + asmlib + libmmt.lib, libirc.lib, svml_disp.lib etc (v14)
So you use icl 10.1?? why?? whats its benefits??
Intel 10.1 more compatible
here is another build (more faster as far as)
http://www.mediafire.com/download/7rhxvwri...tel14_win32.zip
nothing special, GOGO-no-coda ~256kbps VBR + mp3packer
here is LAME with ICL 15 Lib (not tested, should more faster)
http://www.mediafire.com/download/b4o65yxd...tel15_win32.zip
Whats about quality? Is audio quality consistent?
Assuming it compiled ok, it should be the same.
Yes, ICL not always good, i.e. can generate "a broken code" on takehiro.obj/psymodel.obj/vbrquantize.obj as far as (if some "flag" enabled) like a GCC 4.7.x bug
here is "broken psymodel" LAME with ICL 15 Lib (with /QIfist to enable fast float to int conversion)
http://www.mediafire.com/download/e9u8m73d...l15_win32_2.zip
is it necessary to install intel C++ compiler to get better result??
Reply #33
You need the Intel c++ compiler if you want to compile with the Intel C++ compiler.  Otherwise, you don't need it.
Reply #34
Wow... I think something may have gone wrong with this build. Wish the output play correct.
Re: Lame 3.99.5 Intel Lib Compile
Reply #35
Hi all,
  I am using the libmp3lame.dll version 3.99.5 available at rarewares in all my systems but my old laptop with windows xp and without sse2 registers.
  In order to use the programs I created in this laptop I had to download the lame_enc.dll version 3.99.3 from the Buanco site (has the same symbols than the one from rarewares).
  So, now, at runtime I have to decide which of the 2 dlls to use.
  I am not worried with deciding which dll to use at runtime, but I am worried with using different versions of LAME.
  Is there a chance that someone can compile the version 3.99.5 with an old compiler that does not require sse2 and can be used in windows xp ?
  I have also downloaded the version 3.100 from Buanzo's site but I couls not use it in any of my 2 computers, probably because it even requires more recent registers. Is there a chance that someone compiles it for the following 2 configs: 1) the same config as the dll from rarewares; and 2) a config where sse2 registers are not available ?
  If no one can compile the 3.100 version as requested, it would be great if, at least, someone compiled the version 3.99.5 for a setting where sse2 registers are not required....
  best regards,
Reply #36
  Indeed, I have been verifying and my cpu does not have the sse1 registers... so, if someone compiles the version 3.99.5 for me, I will have to ask to not include the sse1 registers.
  best regards,
Reply #37
I'll put a 3.100 compile up later today that should work as required. :) I'll post again when it's uploaded to Rarewares.
John
Reply #38
  That would be really great! Many thanks!
  Just remember that what I need is the lame_enc.dll with the same symbols of your libmp3lame.dll; for the 2 settings...
  best regards,
Reply #39
  best regards,
I assume that you need the same dll that works with Audacity? If so, this one works with the latest version of Audacity and should work on XP. Hopefully it will work for you, but let me know! ;)
lame_enc.dll 3.100 for Audacity
John
Reply #40
  best regards,
The SSE registers launched 20 years ago this February. Do you really have a CPU that completely lacks them?
Reply #41
  Thanks for the dl, I will test it now.
  About the SSE registers, the computer I am using to write this message lacks them; it was acquired on 2001! My other computer has been acquired on 2007!
  I have done a program to batch convert wav and mp3 files https://en.stateful-audio-converter.frdafonseca.com and I have found the mentioned problem.
  As I know several people that is till using old computers I pretend to make the program compatible with old cpus...
  best regards,
Reply #42
  I have looked at the symbols exported by the provided dll and it lacks some which I need, like the hip_* ones, which are available on your libmp3lame.dll.
  Could you please recompile ? And could you provide one version for cpus without sse and one for cpus with them (corresponding to the libmp3lame one you provide on your site) ?
  I pretend to make my program compatible with old cpus but at the same time, I pretend to make it as fast as possible on the said cpus... so I will be testing whether some registers exist and, then, load the correct dll.
  best regards,
Reply #43
OK, I'll see what I can do. I'll get back here when I have something for you. :)
John
Reply #44
  best regards,
lame_enc.dll without CPU optimisation
lame_enc.dll with NASM optimisation
Both contain the library and exports and include all the symbols from the libmp3lame dll as well as the lame_enc symbols.
The first compile is 'plain vanilla' without any NASM or other CPU optimisations, the second is a standard NASM build. Both should run on XP and both work with the current Audacity. Let me know how it goes, please. :)
John
Reply #45
  Many thanks! They both work on my old xp laptop.
  I was expecting one of them not to work, however!
  Can you tel me what are the different registers the dlls use, so that I can choose when to use one and when to use the other one ?
  best regards,
Reply #46
Probably the operating system is swalling the opcode not found exception (for the dll with optimizations) and providing alternative code for it...
best regards,
Reply #47
The one compiled without NASM has no CPU optimisations at all. The one compiled with NASM identifes the CPU and implements optimisations as appropriate:
"assembler routines to detect CPU-features
;   MMX / 3DNow! / SSE / SSE2"
So, the second one should work even if none of those CPU features is present, which kind of makes the first one redundant!
John
Reply #49
You're welcome. ;)
John
