Topic: Displaying total playlist length (Read 3870 times) previous topic - next topic
Is it possible to display total playlist length in statusbar? It is this kind of useless and cool statistics that I would want to know.
It is not listed on http://wiki.hydrogenaudio.org/index.php?ti...e#Playlist_info
I found that it is possible to display it on playlist dropdown ( http://wiki.hydrogenaudio.org/index.php?ti...sts_dropdown%29 ) but I use tabbed playlists.
According to forum search it was not possible in 2003 (http://www.hydrogenaudio.org/forums/index.php?showtopic=5416), 2006 ( http://www.hydrogenaudio.org/forums/index....showtopic=49429 http://www.hydrogenaudio.org/forums/index....showtopic=40797 http://www.hydrogenaudio.org/forums/index....showtopic=43362 ) or 2009 ( http://www.hydrogenaudio.org/forums/index....showtopic=69853 ).
But maybe it is now possible?
Not exaclty the answer you're looking for, sorry, but at least one component features playlist duration: foo_playlist_organizer.
HTH.
Alessandro
Right click on the status bar and tick "Show total time of selection." Note that you have to select items to see their aggregate length. It will simply read 0:00 if nothing is selected.
EDIT:
I just remembered there's a fairly simple WSH Panel Mod script made by marc2003 posted in one of the newer threads regarding playlist length/building playlists. You might find it useful if you can find it. All it does is display title and length of each item and accumulated playlist length per item of the active playlist. It bears repeating that it is only for display purposes.
Just a little addition: foobar2000's native playlist manager can also show the duration of playlists.
that takes more space than a playlist manager panel so probably isn't going to be of use. i did make a much smaller panel in a previous post though. obviously it still needs to go in its own panel but it's a lot more compact.
component: https://code.google.com/p/foo-wsh-panel-mod/downloads/list
script: https://dl.dropboxusercontent.com/u/2280132...list%20time.txt
screenshot:
background/text colours can be customised in the script.
screenshot:
Great job! How can I add more info about "selected tracks count / length" and align it right?
