Topic: 'splain to me how DR meters work, please (Read 4452 times) previous topic - next topic
  • krabapple
Some (many?) audio file playback and editing tools offer 'dynamic range' (DR) analysis or metering..
I haven't used any of them, beyond simple post-hoc calculation of crest factor (peak amplitude - average RMS power) from file statistics that Audition dumps out , e.g.
Notice that it dumps stats for each channel.
What I'm wondering is, how do software DR meters come up with one 'DR' number for a stereo track -- i.e., one number for both channels?
And how would this work, if at all, on a 5.1 channel track , where there is typically large disparity in levels between channels like LFE versus front left?
  • Last Edit: 28 March, 2014, 03:29:06 PM by krabapple
  • skamp
Sample output of the fb2k DR meter component (might be a clue in there):
foobar2000 1.2.9 / Dynamic Range Meter 1.1.1
log date: 2014-03-28 21:22:40
Analyzed: Vangelis / Chariots of Fire
DR        Peak        RMS    Duration Track
DR12      -6.56 dB  -21.95 dB      3:33 01-Titles
DR12      -7.81 dB  -23.72 dB      5:20 02-Five Circles
DR11      -9.25 dB  -27.41 dB      3:14 03-Abraham's Theme
DR13      -0.44 dB  -17.71 dB      4:19 04-Eric's Theme
DR14      -3.56 dB  -23.93 dB      2:02 05-100 Metres
DR11      -1.40 dB  -16.17 dB      2:48 06-Jerusalem
DR16      -0.67 dB  -22.88 dB    20:42 07-Chariots of Fire
Number of tracks:  7
Official DR value: DR13
Samplerate:        44100 Hz
Channels:          2
Bits per sample:  16
Bitrate:          626 kbps
Codec:            FLAC
See my profile for measurements, tools and recommendations.
  • AndyH-ha
There does not seem to be any fb2k DR meter on the page of foobar 2000 components http://www.foobar2000.org/components
Where do you find such a thing?
  • skamp
Mirrored here and there.
  • krabapple
I've seen outputs; I'm curious as to how they are derived.
"The DYNAMIC RANGE METER displays the inner dynamics of a recording in whole numbers or, in other words, the inner grade of compression. More precisely, this is the average cumulative difference between peak and loudness (RMS) over a specific period of time (e.g. duration of a song or album) and is a whole number value given in decibels (dB)." (http://www.tnt-audio.com/edcorner/february09.html)
  • krabapple
But how do they 'average'  more than one channel?
In practice, the values don't differ much across channels. I think the creator was aware that DR is a crude measure. So maybe they're just taking the inf across channels (or the average across channels) even though that's not the rigorous thing to do.
  • Last Edit: 31 March, 2014, 09:02:38 PM by whitewidow
  • mjb2006
Looks to me like it just gets separate DR values for each channel, then averages them.
  • user1
Isn't (shouldn't) "DR" be standardized now (finally) to somehow jibe with the new international standards: E.g., LUFS, R128, ITU BS 1770, ATSC A/85 ...
Some more info here:
http://productionadvice.co.uk/lufs-dbfs-rms/
  • krabapple
They very much do, in 5.1 mixes.  So I'm skeptical of a single 'DR' value for a multichannel mix.
  • markanini
Bob Katz, Ian Shepherd and TC Electronics have discussed 'Peak-to-loudness ratio'. Googling reveals some interesting articles: http://www.google.com/search?q="peak+...ess+ratio"
  • Last Edit: 08 April, 2014, 02:14:01 PM by markanini
  • AliceWonder
I don't put a lot of stock in DR.
There is a video somewhere on YouTube posted by the engineer who mastered the album showing the CD with a DR value of 8 while a needledrop from vinyl had a DR of 12.
Both were from the same identical master.
The differences when examined with a wav editor - in places where the master limited the peak, accurately reflected in the CD, the vinyl had some slightly different wave forms that he speculated was probably the result of the vinyl medium itself, the cartridge, tonearm, etc. in the analog chain between the vinyl and the ADC that recorded the needledrop to digital.
But the master was the same.
When listening to the portions he played, it certainly didn't sound like the vinyl had more dynamic range - it sounded the same.
Anyway point being for me, if identical master has DR of 12 just because there was a vinyle stage between the master and the tool used to calculate DR vs a DR 8 of the CD, then DR is not an accurate way of determining the actual dynamic range. A significantly higher number does not mean it actually has more range, so the value of DR is lost on me.
I expect a recording with low DR value does not have much dynamic range but the inverse is not true, higher DR value does not mean it has good dynamic range. The calculation method is flawed.
I gather it looks at the difference between peak volume and RMS volume, which sounds to be a reasonable method, but that YouTube demonstration shows that it is not actually very revealing and the value can vary wildly without having meaningful difference in the actual dynamic range.
I'll see if I can find the link.
  • AliceWonder
  • markanini
Just did a needle drop vs CD comparison(Allan Holdsworth - Secrets):
CD - Vinyl
Note the PRL values differs 0.1 dB.
  • markanini
Did some more:
PRL CD | LP
Frank Zappa - Jazz From Hell
15.3 | 15.3
Jethro Tull - A
18.5 | 16.0
John McLaughlin - Electric Guitarist
16.5 | 14.6
Cream - Disraeli Gears
17.1 | 15.5
No inflated vinyl scores here it seems.
  • mjb2006
http://www.youtube.com/watch?v=n-AE9dL5FG8
That's the video
This was discussed in the forums here; search for Ian Shepherd. Someone here noted that the one difference on vinyl, i.e. flat-topped peaks acquiring a downward slope, was due to a lowpass filter being applied during the vinyl mastering process. (Shepherd didn't seem to be aware that despite his delivery of just one master, there is still some further processing done for vinyl, e.g. to keep ultrasonic frequencies from overheating the lacquer cutting head.)
This rolloff of the highest frequencies, and the resulting change in the slope of the peaks, was all it took to get a higher DR value. You can also get a higher DR value by reducing the bass... anything you do to lower the peaks without lowering the average by an equal amount will, by definition, give you a lower DR value and shouldn't be surprising. Thus when using the same record, two needledrops made with different equipment can end up having different DR values, due to the different frequency response curves of the analog components.
  • markanini
Ian Shepherd was eventually able to simulate the higher "DR" in TT meter on the digital master simply by narrowing the stereo image.
  • miller-8
Re: 'splain to me how DR meters work, please
So does that mean vinyl has a narrower stereo image than CD? If so why?
Also, I have read a lot about how DR values are not much use for comparing CD to vinyl but are they good for comparing different CD masterings? I mean for example the original Smashing Pumpkins CD releases have higher DR values than the Bob Ludwig remasters yet many people say the remasters sound better.
  • KozmoNaut
Yes. This is due to less separation between the channels, they simply "bleed together" more.
Yes, you can compare different masters of the same album, but keep in mind that a higher dynamic range is not a guarantee of higher sound quality.
  • greynol
  • Global Moderator
I've seen two CD versions of Pearl Jam - Vs. where one had flat tops and the other had them angled but they were otherwise the same, so I don't know that I would treat the speculation/generalizations* posited here as definitive gospel.
(*) low-pass of ultrasonic frequencies to preserve a cutting head, reduced stereo image, DR is safe to use on CD. There are undoubtedly other things worth considering.  FWIW, I'm extremely skeptical that the first of the three will actually matter.  I'm willing to accept my example of the Pearl Jam CD is an outlier, however.
To echo the previous post, one should not use numbers to make a determination as to what sounds better. That is not what this community is about.
  • Last Edit: 31 December, 2016, 12:51:50 PM by greynol
  • miller-8
What do you mean by flat tops and angled. And which do you prefer the sound of?
  • greynol
  • Global Moderator
After proper level matching there is no audible difference.
https://hydrogenaud.io/index.php/topic,80679.msg704105.html#msg704105
That will hopefully open Pandora's box, as there are similar examples where that came from.   I've taken great sport in shooting down examples posted with the intention of "proving" that vinyl did not come from the same clipped digital master used to create a CD. This is in relation to flat-tops being angled, mind you. It is the tell-tale sign. I was quite surprised to see it also on CD, to be honest.
  • Last Edit: 02 January, 2017, 12:12:25 PM by greynol
  • CuteStudio
Angled flat-tops is merely bass EQ being applied after clipping.
Any square wave sent through bass EQ will show the same thing, it's basic electronics.
Seeing angled flat-tops of vinyl infers nothing, 80s synth music is full of them.
Creator of the SeeDeClip4 multi-user Declipping Music Server.
Download your free copy now.
