Topic: Horrible performance of lossless codecs (Read 8773 times) previous topic - next topic
  • Garf
  • Developer (Donating)
http://sjeng.org/ftp/vorbis/Garf_Bl33p!.flac
Any idea why the performance of most lossless codecs is so horrible on this very simple signal?
I would expect prediction to be almost perfect for it.
But:
FLAC bitrate:580kbps
APE bitrate:750kbps
WavPack: also >500kbps
ZIP bitrate: 21kbps
7z/RAR bitrate: 2.5kbps
  • k.m.krebs
I just tried it with optimfrog using the 'normal' compression setting, and the output size was 51.9 KB.
k.m.krebs \ 833-45: http://833-45.net
  • rompel
  • Members (Donating)
But:
APE bitrate:750kbps
ZIP bitrate: 21kbps
bzip2 131bps
I think the problem is with the use of Rice-coding.  My understanding is that it was designed for normally distributed residuals, and is decidedly sub-optimal where you have mostly zeros with an occasional + or - 65535.
Good test sample!
--John
  • bryant
Those last few percent of compression that the best lossless compressors get is at the cost of an enormous amount of complexity in the prediction algorithms. They look at dozens of previous samples and have dozens of adjusting coefficients. So, a single transition will generate a whole train of non-zero residual values to encode. Another version that simply used the previous sample as the prediction would encode this much better, but would virtually never work better on any sample of real music (in fact, WavPack's "fast" mode compresses this sample to about half the size of the "high" mode for this reason).
Also, no lossless compressor is going to take advantage of exactly repeating sequences of numbers like a general data compressor, because these never occur in audio data and require completely different coding algorithms (i.e. dictionary based, no Rice coding).
An "ideal" compressor could be made to try several different simple and complex algorithms to detect cases like this, but most people would not be willing to put up with the encoding time penalty unless it improved performance on any "real" samples.
BTW, your sample scared my cat!
  • jcoalson
  • Developer
But:
APE bitrate:750kbps
ZIP bitrate: 21kbps
I think Bryant's right.  Note that for regular signals like this, tuning the blocksize in FLAC gets you a lot, e.g. "flac -8 --lax --blocksize=384" is about 169kbps.  But BWT compressors like bzip2 will really kick on this signal, they'll probably use just a few bits to encode a single cycle, and a little for the dictionary.
Josh
  • NumLOCK
  • Developer
Garf, I haven't looked at the WAV yet, but that FLAC file is very very strange ! It looks like a killer sample for RAR !
Original (FLAC) = 4'394'931 bytes
RAR (Best) => 80'162 bytes
RAR (Good) => 81'523 bytes
RAR (Normal) => 27'680 bytes
RAR (Fast) => 55'240 bytes
RAR (Fastest) => 105'302 bytes
Just looking at the FLAC output with a hex editor shows that it's extremely redundant.
Try Leeloo Chat at http://leeloo.webhop.net
  • NumLOCK
  • Developer
I win !  B)
My packer projects brings the .WAV down to 76 bytes.
Compression ratio: 1:139264
  • Atlantis
This problem can't be avoided adding a function, in lossless codecs, that checks if the output file is redundant as numlock noted and changes the compression mode used?
Just my 0,0000002 euros
edit = well the problem of time penalty will still be there...
  • Last Edit: 18 June, 2003, 05:12:43 AM by Atlantis
Vital papers will demonstrate their vitality by spontaneously moving from where you left them to where you can't find them.
  • Peter
  • Administrator
If we're into RAR killer samples, I remember seeing some files (it was some Unreal Tournament mod IIRC) where RAR miserably lost it to ZIP, even to its own ZIP compressor. I can dig them up if anyone interested.
  • NumLOCK
  • Developer
Your file might make RAR heuristics fails, and thus pick the wrong algorithm
If you still have it I'd be interested, yes.
  • eltoder
Sorry, Garf, but why you have uploaded FLAC instead of ZIP than?
-Eugene
The  greatest  programming  project of all took six days;  on the seventh  day  the  programmer  rested.  We've been trying to debug the !@#$%&* thing ever since. Moral: design before you implement.
  • Tripwire
Had the same idea. Some ultrasuperduperhigh compression mode would run two compressors at once, the regular audio compressor and e.g. a ZIP compressor, and then store the blocks that are compressed the most.
  • thop
  • anza
At least that sample made me understand the true performance of my dial-up modem (56k):
  • Garf
Your modem uses compression, you could say it zips-on-the-fly.
I didn't realize it zipped so well until after I uploaded it.
  • NumLOCK
  • Developer
Zero-knowledge compressors have a big advantage on this "audio" sample:  they don't believe it's audio.
After seeing a short header, followed by a few alternances of:
FF7F (ie: 32767 in hex & reversed byte-order) repeated 102 times
and:
0080 (ie: -32768 in hex & reversed byte-order) repeated 100 times
... the packer will suppose this would continue for a long time.
For example, in a well-tuned arithmetic coder you can encode a whole alternance (2*102 + 2*100 bytes) in a matter of bits.
Using arithmetic coding, if you remove the WAV header one could encode this whole file in less than 10 bytes, and still be able to handle any input file (or unexpected data at the end of this file) correctly.
Even if you know the repeating sequence has a very high probability to appear, you still must reserve those 0.000001% probability for all other cases. That's also why the file would take 10 bytes, and not zero bit
Huffman encoding, on the other hand can only assig whole bits, ie:  it can assign "0" to the most common sequence, and "1xxxxxxxxxxxxxxx..." to all possible others.
  • Last Edit: 18 June, 2003, 08:25:58 AM by NumLOCK
  • eltoder
Yes, and bzip is the winner here. It compressed the file to 983 bytes. WinRar (with PPM forced) compressed to 4755 bytes.
Such results are pretty obvious and very similiar to those of Short_Block_Test_2, which is very sparse as well: http://eltoder.nm.ru/temp/Short_Block_Test_2.res
-Eugene
  • NumLOCK
  • Developer
RAR 3.x can shrink the wav further to ~4756 bytes, when forcing markov ("text") compression at maximum order (99).
Edit:
LOL eltoder, what did you do to RAR, to gain that extra byte ?
About bzip2, cool but that's still far away from my 76 bytes.
  • Last Edit: 18 June, 2003, 08:53:03 AM by NumLOCK
  • eltoder
Edit:
The maximal order is in fact 63, not 99. And the best results are obtained at order 60
And could you share you great program with us?
-Eugene
  • NumLOCK
  • Developer
-Eugene
Oh. I should have tried all possible values then
Well, why not.. (thanks for the compliment btw) but I'm a bit ashamed, it's awfully slow, and optimized for data, not audio (except for Garf ® © audio of course). Also the name of input and output files is hardcoded in the source..
Edit:  Btw I absolutely love your signature !
  • Last Edit: 18 June, 2003, 09:10:41 AM by NumLOCK
  • eltoder
I absolutely need this program!
And I like my sig too, but now I think it's a bit long
-Eugene
  • NumLOCK
  • Developer
Ok, I'll send it to you tonite
Be advised though, to compress such files well I had to hack the probability modelling curve.. so you (or we) would have to find the parameters again.
Also, it's a bit-based program (it compresses bits, not bytes). However, it uses heuristics and tries to still exploit byte, word, dword alignments, when it is possible.
The probability estimation part is a mess, it uses variable-length PPM, hashtables, dynamic decay curves, etc etc.. It looks more like a nuclear physics simulator than a packer. I think a complete rewrite should be done ASAP
IIRC, I have an improved arithmetic coding backend, and crazy ideas lying around, that I could use in the new project (when time allows).
Edit: I'll have a bit more time when my laptop's back from Shinjuku-Ku with a new hdd.
  • Last Edit: 18 June, 2003, 09:40:00 AM by NumLOCK
  • JamesBond
SBC Archiver 0950 beta:
sbc.exe c -m3 -b63 newarchive Garf_Bl33p!.wav
compresses to 217 Bytes...
  • Last Edit: 18 June, 2003, 10:23:12 AM by JamesBond
  • NumLOCK
  • Developer
Very impressive. It blasts away RKIVE, 777...  even though the latter uses arithmetic coding.
Edit: SBC is one of the 1st archivers to associate block-sorting and arithmetic coding
  • Last Edit: 18 June, 2003, 10:50:57 AM by NumLOCK
  • eltoder
All of them do. Imagine PPM or BWT without arithmetic coding?
-Eugene
