Topic: Prevent file renaming while transcoding (Read 3046 times) previous topic - next topic
Hi, all,
I am transcoding my AIFF library to FLAC format with XLD. I can't see any preference that would prevent the app from renaming files. Specifically, it adds the artist's name by inserting it between the track number and the track title. There must be some simple way to tell the app to leave the file name alone, but I can't find it. I would appreciate help with that. I am using the latest version of HLD on MacBook Pro running OSX Mountain Lion.
AllEars
  • JJZolx
I don't use XLD, but could it be honoring a file naming convention set elsewhere in the options, perhaps the same one used for ripping?
Well, the CD Rip preference pane does not contain anything that would change the naming/renaming behaviour. There is a separate File Naming preference pane, though, which includes two alternatives: Default and Custom. The Default gives me as a result a file that is renamed. I have no idea how to use the Custom alternative.
Any more suggestions, please?
  • Last Edit: 23 February, 2014, 05:50:08 PM by AllEarsJunkie
  • JJZolx
So, you've ruled that out, because you can't be bothered to figure out how "custom" works and then test it?
  • korth
You could try searching in the Hydrogenaudio Knowledgebase:
specifically XLD Configuration: File Naming tab
Edited for content
  • Last Edit: 23 February, 2014, 06:09:16 PM by korth
korth
Hi, korth,
This was somewhat helpful, in that I now know the %t placeholder stands for the title of the song - which is fine. But adding the %n (track number), changes the original track number, which is replaced by the one assigned by XLD. If I don't use the %n placeholder at all, then no track number is written to the file's name (which means that I lose the track number from the original disc).
My goal is to retain the original name without altering it in any way. I only want to transcode the file format from AIFF to FLAC and embed the artwork. Is that possible with XLD?
  • Last Edit: 23 February, 2014, 07:11:25 PM by AllEarsJunkie
  • Porcus
Couldn't you use command line and -o to <oldfilename>.FLAC?
Hi, Porcus,
This sounds so simple, but I am not a programmer/coder. Command line is a mystery to me. Could you elaborate just a little bit more? I never used Terminal before, so hand-holding would be much appreciated. Sorry for my ignorance...
  • korth
I don't have access to a working mac right now and it has been a while since I last used XLD but from what I remember if the metadata is correct then %n should be correct.
You could check 'Edit tags before convert' on the 'Metadata' tab. This will force XLD to stop and prompt you to review and edit the tags before the conversion. You should be able to fix the track numbers there.
korth
  • Porcus
Hi, Porcus,
Well, I usually mess up command lines myself.  And syntax differs from shell to shell ... I don't even know what the fruitware uses. And I cannot test the XLD syntax.
Maybe this is something for you: http://www.makeuseof.com/tag/max-the-multi...nverter-in-mac/
Yeah, I'll check it out. Thanks. In the meantime, maybe someone else, who uses XLD, could chip in with another advise? That would be great...
  • nu774
xld seems to support CLI interface. To convert foo.aif to foo.flac,  something like the following should work:
xld -f flac -o foo.flac foo.aif
Converting multiple files keeping the directory hierarchy can be done like the following. It can be achieved by a relatively simple script, but it might be difficult if you have never used shells in the terminal:
#!/bin/sh
case $# in
2) SRCDIR="$1"
   DSTDIR="$2";;
*) echo usage: $0 SRCDIR DSTDIR 1>&2
   exit 1;;
esac
(cd "$SRCDIR" && find . -name '*.aif' -o -name '*.aiff') | while read FILE
do
    FILE="${FILE#./}"
    mkdir -p "${DSTDIR}/${FILE%/*}"
    xld -f flac -o "${DSTDIR}/${FILE%.*}.flac" "${SRCDIR}/${FILE}"
done
Thanks a lot! When I'll find the courage to mess around with the Terminal, I will certainly try your script. But I will also be on a lookout for some other application that does not force me to rename my audio files or to start a computer-science course in order to prevent it from altering the file's name.
I'd like to thank all of you who tried to help me with this predicament...
  • Apesbrain
You may want to give xACT a try:
http://xact.scottcbrown.org/
http://mac.softpedia.com/progScreenshots/x...nshot-3897.html
http://lifehacker.com/5804929/xact-is-a-li...ool-for-the-mac
Functionally, it looks like it does the same things as XLD but maybe its file naming conventions are closer to what you want.
