Topic: Batch reverse phase (Read 2035 times) previous topic - next topic
Batch reverse phase
Dear all,
a friend of mine made a stupid mistake by making his own interconnects and recorded a few vinyls with that cable. The files are ok (48/24), but the phase is reversed (here in Croatia we have a term loosely translated as "contraphase"). So, I need to reverse phase of just one channel. I know how to do that in Audition, it's fairly simple - but I don't have it  and Audacity requires me to first split the file into two mono channels, then select one, reverse it, and join them together.
Yeah, I can do that in around ten to fifteen minutes, but I was wondering - can I do that in batch, with sox, for example? It will be done either way, just wondering if there is sox option for that - I've googled it up, but can't find anything about reversing phase of just one channel, and NOT reversing the whole file or reversing the file so it plays backwards.
Thank you very much.
TAPE LOADING ERROR
Batch reverse phase
I think it's something like
sox inputfile.wav outputfile.wav remix 1 2i
FYI, 'reversing phase' is usually called inverting.
Batch reverse phase
Thank you very much, this works. And "inverting" is probably the cause why I haven't found much searching about the problem
TAPE LOADING ERROR
