Here is my situation:
Phonic Digitrack on Windows 7 with Polytec usb-audio.com ASIO drivers.
Using Reaper I can capture DTS from Laserdisc. Captured file is here
It plays back in Reaper & ALSO plays back in fb2k with SPDIFER plugin for foobar2000 v1.1+ via Digital Out to external Aplifier (that does the decoding)
So all is fine.
But nothing can be done with the file (besplit does not work on it)
If I pick DTS Piano trailer & demux it with vobrator, the resulting file does not play (digital noise)
besplit can deal with this wave, and produce .dts
But this .dts is also not playable (same digital noise)
I understand that the captured file is bit perfect & fb2k plays it back as such to an amp
But why does not play "proper" dts file?
And does anybody know how to process captured file
(which shows as:
WAV, 2.0 channels, 0:00:29, 16 bits, 1411kbps, 44.1kHz
Length: 0:29.115
Sample rate: 44100
Channels: 2
Bits/sample: 16 (int)
Total samples: 1,284,007
Blockalign: 4
Datablock start: 736
BWF chunk:
Originator: REAPER
Date: 2014-02-05
Time: 19-50-10
Start offset: 0:00.000
so it could be muxed to mkv
sebus
