Topic: foo_youtube (Read 519089 times) previous topic - next topic
Re: foo_youtube
Reply #1300
IIRC foo_youtube only support VSFilter or xy-VSFilter and only 32-bit version
Re: foo_youtube
Reply #1303
Hi all, I have a problem.
I adding my youtube playlist via File -> Youtube Source -> Load channel or playlist...
There is a playlist created in Foobar, all is OK
But in View -> Youtube Source -> Auto-Updated Playlists - it's empty, I can't see this playlist
Re: foo_youtube
Reply #1304
Is this a channel? If so, have you clicked on the playlists entry again after it was added? Some time ago, the behavior was changed so that when you first add a playlist, you need to select it again for it to show up in auto-updated playlists.
Re: foo_youtube
Reply #1305
Yep it's a playlist, with "/playlist?list=" in the link
I tried to select it, play it, but no luck - auto-updated playlists window still empty
I'm using Foobr2k 1.4.3 with the latest subj 3.6.1
Re: foo_youtube
Reply #1306
Is this plugin updated anymore? I go to help/youtube source/check updates, and it tells me it's the latest, yet the search doesn't work, and I have to rely on youtube-dl for playing.
Re: foo_youtube
Reply #1307
foo_youtube works flawless on my side including search.
Re: foo_youtube
Reply #1308
I don't think it's updated anymore no. The developer haven't update any of their tools since July I think.
I have the same issue with the search not working etc.. It is possible that it would work with a YouTube API key, but I haven't bothered going through the steps to get one myself.
Re: foo_youtube
Reply #1309
Bonjour,
Je suis utilisateur foobar2000 depuis quelques semaines. J'ai adopté ce lecteur parce que c'est à ma connaissance le seul gratuit permettant d'utiliser les filtres FIR grâce à Foo_convolve.
Juste après l'installation il ne lisait pas les vidéos. Après quelques recherches, j'ai installé "LAV filters" qui me permet de les lire à présent directement dans foobar.
Dans la foulée, j'ai aussi installé Foo_youtube.
Je suis donc novice, confronté à plusieurs problèmes, et me suis inscrit sur ce forum que j'ai découvert il y a 2 heures et dont je ne connais pas encore le fonctionnement. Il semble en langue anglaise mais je lis les posts dans un Français d'une qualité surprenante pour que ce soit une traduction automatique Google. Dites moi si je dois rédiger en Anglais pour la suite, ce qui me sera pénible mais pas insurmontable. Merci d'avance pour ceux qui me répondront. Je viens de remarquer que dans l'aperçu, le message est parfois modifié par rapport à ce que j'ai écrit.
Mon premier problème est un décalage d'une bonne demi-seconde entre son et image, conséquence d'une convolution de 32000 "taps" par voie. Existe-t-il un composant qui permette de retarder l'image précisément ?
Le deuxième problème est un fonctionnement bizarre de Foo-Youtube mais qui n'est peut-être pas de mon fait. Je cherche une vidéo sur le site de Youtube, je copie l'URL et la copie dans le champ "Add multiple URL's" du menu "youtube source" Cela ne fonctionne pas sur de nombreuses vidéo. Rien ne se passe. Parfois cela fonctionne très bien.
Quand cela ne fonctionne pas, je colle l'URL dans le champ "add location" et cela fonctionne alors très bien à chaque fois pour la dizaine de vidéos que j'ai testées.
La deuxième bizarrerie est que le lendemain aucune des vidéos présentes dans la playlist que j'ai faite la veille ne fonctionne. J'ai parfois un message qui me dit que je n'ai pas le droit de la lire et parfois cela ne fonctionne pas tout simplement. Je crois que Youtube identifie Foobar et bloque la lecture ?
Qu'en pensez vous ?
Cordialement,
Luis
Mod edit:
TOS 10 - All members must post in English.  Content in other languages are allowed as long as full English translations are provided, or otherwise at the discretion of the staff.
Hello,
 I am user foobar2000 recent weeks.  I adopted this drive because it is to my knowledge the only free for using FIR filters through Foo_convolve.
 Just after installation he did not read the videos.  After some research, I installed "LAV filters" that allows me to read now directly foobar.
 In the process, I also installed Foo_youtube.
 I am a novice, faces several problems, and I signed up on this forum that I discovered there 2 hours and I do not know yet operation.  It appears in English but I read the posts in French in a surprising quality for either an automatic translation to Google.  Tell me if I have to write in English for the sequel, which will be painful for me but not insurmountable.  Thank you in advance for those who meet me.  I just noticed that in the preview, the message is sometimes altered from what I wrote.
 My first problem is a mismatch of a good half a second between sound and image, the result of a convolution 32000 "taps" per channel.  Is there a component that allows to delay the image exactly?
 The second problem is one odd-operating Foo Youtube but is perhaps not my doing.  I am looking for a video on the YouTube site, I copy the URL and copy in the "Add multiple URL's" menu "youtube source" This does not work on many video.  Nothing is happening.  Sometimes it works very well.
 When this does not work, I paste the URL in the "add location" field and then it works very well each time for ten videos I tested.
 The second oddity is that the next day no videos in the Playlist I made the day before work.  I sometimes get a message that says I have no right to read and sometimes it does not work simply.  I think that YouTube identifies and blocks Foobar reading?
 What do you think ?
 Regards,
 Luis
Re: foo_youtube
Reply #1310
hi, I have an issue. I have Search on Site opened, the focus on other app or just click on Desktop, then back to Search on Site window. I can't type anything on search input until I click/focus to foobar2000 main window. Regards.
Re: foo_youtube
Reply #1311
Wrong =)
https://fy.3dyd.com/changelog/beta/
Re: foo_youtube
Reply #1312
Wrong =)
You beat me to it :). Yes, thankfully I was wrong.
Re: foo_youtube
Reply #1313
Would it be possible to add additional support for the way Youtube Source displays album art as a fallback background when video isn't loaded? (as configured in the  'Youtube Source > Video > Window' options)
Right now, as far as I can tell, it is only able to display album art that is attached as an image via the 'Properties > Artwork' dialog. It would be wonderful if it could also display an image found in the same folder the file is being played from (e.g. if a youtube URL is saved to an .m3u file and there was alternate album art saved to the folder the .m3u file was saved to).
Re: foo_youtube
Reply #1314
Is there any way to save the youtube video which I'm watching with foo_youtube?
Re: foo_youtube
Reply #1315
to my knowledge not directly in foo_youtube, but using youtube-dl within foobar via foo_run, see here
Re: foo_youtube
Reply #1317
I've been experimenting with VSFilter to try and get subtitles working, but I can't seem to get embedded subtitles to display over the video, Do subtitles still work in this component? I have my VSFilter source set to managed, and have the latest installed, but can't seem to access the configuration panel for it (or where to find the configuration option).
Re: foo_youtube
Reply #1318
This should dump the cache when closing foobar so that it does not continue to take up hard drive space. It can reload the metadata if selected again by the user. Also, I get a persistent 403 error after playing 1 video. Closing and reopening Foobar allows me to select 1 new video. Anyone have ideas?
I am on the latest Foobar iteration and Beta for Foo_youtube.
MAK
Re: foo_youtube
Reply #1319
@3dyd Hi, could it be possible to play a local file with external subtitles (.srt for instance) using xy-VSFilter?
Re: foo_youtube
Reply #1320
The HTTP 403 error started appearing again when attempting to play (music) videos on official accounts. Video on non-official accounts work fine.
I noticed that the 'SIDCC' parameter within the cookies info is updated with every request to YouTube, and the expiry date is set to the current date. This happens both in-browser and within foobar2000. The cookies.txt file is updated when calling videos via foo_youtube, so I assume this is expected behavior?
I used to be able to 'fix' this issue by restarting foobar2000. That doesn't work anymore. Renaming foo_youtube's cache directory to enable foo_youtube to recreate it and setting the user agent to the one my browser (Chrome, latest version) is using didn't work either.
[UPDATE] It just started working again, out of the blue. I did update the user agent once again (Chrome wasn't fully up-to-date after all).
Re: foo_youtube
Reply #1321
Thank you, renaming the cache folder and then adding my browser's user agent fixed it.
I have a different question - how do I make the plugin completely ignore the uploader's channel name? Currently, it adds the uploader as "Artist" in the metadata.
The plugin also has an included "metadata pattern" which does a different thing - it parses the video title and tries to semantically guess the artist and add it to the metadata. But I'd rather it leave the video title as it is, and just ignore the uploader.
Re: foo_youtube
Reply #1322
Or perhaps a different tag could be used for the uploader.
Re: foo_youtube
Reply #1323
I assume you're replying to me - how would that be done? I imagine it's possible to write a regular expression which just does "grab the video's title as a <title>, do nothing else". Unfortunately, I'm unable to write regular expressions as I do not have a box full of rabid squirrels to throw a keyboard into.
Re: foo_youtube
Reply #1324
Unable to open item for playback (Youtube Source: foo_youtube: server error (403) from r3---sn-u2oxu-3g3e.googlevideo.com | ffmpeg: Server returned 403 Forbidden (access denied) | foobar2000: Access denied):
"www.youtube.com/watch?v=sDHqywS6un0"
Started today for every  YT video.
