Topic: foo_youtube (Read 196035 times) previous topic - next topic
Re: foo_youtube
Reply #775
Yes, that happens from time to time due to internal changes on Youtube. In such cases it just need to wait a bit until new component version, adapted for that change, will be created.
This time it seems that the change was not permanent - today clips are being played fine. But anyway, update with the fix preventing from that sort of issues in the future is on the way.
Re: foo_youtube
Reply #776
I don't have problems, but thanks for the fix :)
Re: foo_youtube
Reply #777
Does this plugin support live streamed video/audio on YT?
Re: foo_youtube
Reply #778
Bug found.
Description: foo_youtube incorrectly parses youtube playlist, when it contains more than 50 items.
Nvm, it's a feature and not a bug...
Re: foo_youtube
Reply #780
Hello,
Is there a way to use DSPs with foo_youtube ?
It seems that it bypass all foobar dsps to output.
I need to use sox and advanced limiter for exemple.
Christophe
Re: foo_youtube
Reply #781
how add videos from music channel sorted by popularity?
From within component there is no way yet.
Audio output is performed by foobar (including DSP along the way), not by the component. Component acts as decoder, so it does not affect the rest of audio processing chain. Thus, unless these DSP use some specific way to operate (I'm not familiar with DSP side in foobar), they should work. E.g. normalizer, crossfader, resampler, tempo work ok.
Re: foo_youtube
Reply #783
hi, I'd like to know how to do that too. I tried to move the link (drag'n'drop) into f2k playlist and I tried to do copy, ctru-u and paste too, but i always get the same error:
Unable to open item for playback (Youtube Source: Page analysis, no video found on Youtube URL)
Re: foo_youtube
Reply #784
Live streams are not supported yet.
https://hydrogenaud.io/index.php/topic,104379.msg932789.html#msg932789
| TAK pMax | QAAC ~ 192 kbps |
Re: foo_youtube
Reply #785
@3dyd Can you please support multiple selections for "Copy URL"?
For example: I select 6 songs and I click "Copy Name", I get the names of these songs.
I select 6 Youtube links and I want to do "Copy URL", so I get URLs of all selected Youtube links.
Right now I have to click "Copy URL" for every song.
Re: foo_youtube
Reply #786
Ok. For some context menu items one track is a reasonable maximum, but "Copy URL" is definitely not one of them.
Re: foo_youtube
Reply #787
@3dyd : hey there, it seems I have a bug for you =)
I'm encountering a lot of 'server error (403)'. Only started recently (may be even today). Probably something with YT API.
Using latest 1.18.4 version.
Example videos: http://youtube.com/watch?v=avE5GkQ3J0w , http://youtube.com/watch?v=Lb-vIpdMagU
Re: foo_youtube
Reply #788
Yeah. A sign from the heavens, hinting to stop tinkering and finally make an initial release.
Ladies and gentlemen, I'm glad to introduce version 2.0
Re: foo_youtube
Reply #789
Lovely, with live stream support! Thank you 3dyd for your hard work. Testing live stream now, so far so good.
@TheQwertiest same here, 1.18.4 can't play some streams, but 2.0 beta 4 works well at the moment.
Re: foo_youtube
Reply #790
hi 3dyd
in new version bug?
in previous version i generated "hh_ello.m3u" file with content
https://www.youtube.com/watch?v=QpBnWbVBTWo
https://www.youtube.com/watch?v=gPSGjZQt9NM
https://www.youtube.com/watch?v=QXDRPtufEbA
https://www.youtube.com/watch?v=fuPX8mjeb-E
... next 2052 lines
then i foobar->file->add files add him to playlist and then play
but in beta 2.0 i get errors when play button
Unable to open item for playback (Unsupported file format):
"https://www.youtube.com/watch?v=QpBnWbVBTWo"
Re: foo_youtube
Reply #791
Yay for the stream support! One problem though - I can't find download link to 2.0 anywhere... Am I missing something or was it pulled down from the site?
Re: foo_youtube
Reply #792
Probably, Reload current page.
https://fy.3dyd.com/download/
SHURE SRH1840, SENNHEISER HD660S, Beyerdynamic DT 1990 PRO, HIFIMAN HE400i, Ultrasone Performance 880, AKG K712 PRO, Bowers & Wilkins P7, SONY MDR-1AM2, Bose QuietComfort 35 wireless, SENNHEISER HD 4.50BTNC (made a Upgrade/Balanced Cable by myself)
Re: foo_youtube
Reply #793
Yeah, it seems that firefox caches pages now, because download link appeared after force refreshing the page (CTRL-F5) :\
Re: foo_youtube
Reply #794
hmm i append fy+ to http: but very very slow opening m3u file with 2000 lines to playlist
Re: foo_youtube
Reply #795
@charlie_su1986 thank you
That was due to misconfiguration of cache control on the server. Fixed, thanks.
... next 2052 lines
Ah. I was not aware of use cases when track path can retain original URL scheme, And this is one of them.
Fixed in beta5. For supported URLs without custom scheme was added redirection to fy+ when track info is requested or decoding starts. Files with http and https schemes are "remote", which affects their processing. [If I understand correctly] when such file is part of playlist, file info is not requested when playlist is being added. So you'll get your big playlist loaded instantly, but without metadata. Remoteness also means at least that embedded album art will not be loaded for such files. In context of this component that means there will be no thumbnail as album art. And metadata edit is also not possible (either because file is remote or because it is http/https).
That is because unlike http/https, fy+ files are declared as "not remote" by the component. So file info gets requested when such files are added from playlist. If you don't have yet that info in the cache, a clip analysis will be initiated, which may take few seconds per clip. So adding a large playlist may take a long time. Though when you'll add it next time, that will be quick.
Re: foo_youtube
Reply #797
Feature Request.
Add option to ad "Twitch" streams to playlist.
Re: foo_youtube
Reply #798
@3dyd
First of all, congrats on a great work... this youtube plugin for foobar2000 has been a life saver when it comes to playing music during my twitch streams.
However, I have a couple of issues with this new 2.0 beta 5 version...
First Issue: All of my musics started rewriting their "tags" (artist, title, etc.). I went to quite a lot of work to set them right so that they only show "<Artist> - <Track Title>", removing a lot of unecessary stuff (taking "lyrics" from titles, for exameple), etc.
The pattern that i'm seeing is that they are putting the full youtube video title on the Title field and the uploader of the Youtube video on the Artist field.
However, this issue is not so bad cause I think I can remake them. I just wanted to know if there's a way to prevent this from happening or revert back to old behaviour (cause remaking them all again will take some time).
UPDATE: Ok, so this issue isn't really an issue. I was reading through ur change log information about this new version and saw that the "Metadata construction changes" where u explain the changes that caused this issue. I've reverted back to the 1.x version (with the "Enable clip title parsing rule") and it's no longer changing my titles. Only a few were changed, nothing biggy.
2nd Issue: The replaygain doesn't seem to be saving. I had ran a replaygain on ALL my tracks so that they would be all on the same volume level. That way, I wouldn't have to be worrying about changing music volumes in the middle of the stream cause one song is too loud or low compared to others, they would all run at the same volume level.
This issue is a bit more important because i've tried running replaygain calculate on some musics and upon saving my playlist and closing the software, it doesn't seem to "stick / save to the file tag.
Can you help? :)
Thank you....
Keep up the great work.
Re: foo_youtube
Reply #799
@Wolfbane
Before adding new features it's need to finish existing ones.
@tsunami2069
Ok. 2.x will be able to pick up metadata and properties left from 1.x version. In next beta.
Regarding to replaygain - I overlooked that, thanks. Will be fixed too.
