Topic: foo_youtube (Read 682864 times) previous topic - next topic
Re: foo_youtube
Reply #1650
I checked this on a couple of different computers and on both, the same result. The monitor turns off when playing a youtube video. I think the computer configuration has nothing to do with it.
Re: foo_youtube
Reply #1651
https://mega.nz/file/MatHRRQb#wc8ceMHtrwuDV-zyF-_jxrxwAao96d0dKCGBaf6r63Y
yd folder
C:\yd
foo_youtube.dll.cfg: replace
\profile\configuration\foo_youtube.dll.cfg
Preferences > Tools > YouTube Source > Maintenance tab > YouTube API Key: input
Restart foobar
Replacing the oo_youtube.dll.cfg with the one your provided did the trick for me.
I use foo_youtube with yt-dlp to listen to the music of videos. The problem started to happen when playing AAC audio. Playing AAC audio used to work. Playing music with Opus codec was not affected.
Interesting to see that recreating that config file helped to get things moving again. Thank you.
Re: foo_youtube
Reply #1652
Sorry for dummy question. Am I understand this plugin right? I open some link from YT and foobar open it. Or I must do some magic rituals to make it works?
I add it to my foobar, add all deps. But it didn`nt open yt links still.
Re: foo_youtube
Reply #1653
In the menu go to File --> Youtube Source --> Add multiple urls. You can now add urls. Make sure you have the tab open you want them to be in.
Re: foo_youtube
Reply #1654
Hi there. I don't know how to make it work again. I have the latest foobar but I can't make it play a song directly by the URL. I need to open it on browser in order for the song to play.
Re: foo_youtube
Reply #1655
Someone has get this working again ?
I get the error:
Unable to open item for playback (Youtube Source: foo_youtube: server error (403) from rr1---sn-8xgn5uxa-4g5d.googlevideo.com | ffmpeg: Server returned 403 Forbidden (access denied) | foobar2000: Forbidden (403)):
"www.youtube.com/watch?v=mQpi9-lo3l0"
Re: foo_youtube
Reply #1656
I get the error:
Works here without problems...
Re: foo_youtube
Reply #1657
I get the error:
Are you logged in with API Key ?
In my case im not logged in.
I cant open googlevideo.com on my browser
Re: foo_youtube
Reply #1658
My Config works now in Windows 11 with youtube_dl set to external
But in Linux Mint under Wine it still not works.
Ideas ?
:Edit: I get it working ! :) use from https://github.com/yt-dlp/yt-dlp-nightly-builds/releases the
yt-dlp_x86.exe for Wine this works fine
Re: foo_youtube
Reply #1659
Hello good people... i Tried all yt-dlp versions but can get it to work... 403 error... Anybody have working youtube on foobar now?
Re: foo_youtube
Reply #1660
I want to thank the author for this plugin and  to mention for anyone interested that there is a somewhat hidden function which I always wanted and never knew it existed: If you want search box focus by default when search window pops up, right click title, select "Initial focus to search box".
Re: foo_youtube
Reply #1661
Hello. Can someone help me how to make this work again? I've been trying yt dlp but it's still the same. I had to open the song in browser before I can play it.
Re: foo_youtube
Reply #1662
I got it to work after updating BOTH yt-dlp.exe and extracting all my browser cookies using an add-on and putting them into the extension storage.
Re: foo_youtube
Reply #1663
Am sorry am noob, what addon and what cookies? how do you put them into foobar2000?
YOU TUBE configuration problem error for all
Reply #1665
impossible to play you tube with forbar2000 still errors whatever the mode used, yet the codec is well installed
ex ; Unable to open item for playback (Youtube Source: foo_youtube: server error (403) from rr5---sn-25ge7nzr.googlevideo.com | ffmpeg: Server returned 403 Forbidden (access denied) | foobar2000: Forbidden (403)):
"www.youtube.com/watch?v=tVKWiseNGUU"
but by searching site it finds them for me without any problem I lost objective listen to you tube via foobar to listen to it via amp on my speakers which works very well in direct listening library
Open Source Music: when skills and creative geniuses come together for the happiness of all.
Re: foo_youtube
Reply #1666
I suspect that youtube detects the plugin and blocks it directly. You can still try to change the browser identification sent by foo_youtube. But I suspect that won't work either.
Re: foo_youtube
Reply #1667
I'm afraid of it because whatever the codec mode always error message forbidden not recognized impossible to etc...
Re: foo_youtube
Reply #1668
even in private and under vpn same problem
Re: foo_youtube
Reply #1671
updating youtube-dl from Preferences solves the problem
