Topic: Stream system audio from soundcard to foobar (Read 10959 times) previous topic - next topic
I'm trying to stream all of my audio through foobar because I have a bunch of tweaks which make the sound better for me. Is there an easy way to do this? I have foo_record and have a stereo mix option in record settings which works (tried through audacity) so I'm just looking for a way to stream audio through foobar whenever I'm listening to songs on youtube. I have searched high and low but there isn't any solid information as far as I saw.
(before you say anything, I don't see much of a difference between youtube and other things because 1. it's just background music most of the time 2. once I start seeing differences I'm gonna be screwed with all of my low quality mp3's so I don't want that thank you very much [kinda like I'm a graphics whore in games and now I have a hard time playing subpar graphic games. Ignorance is bliss sometimes.])
If you use windows: http://dangerousprototypes.com/2013/05/04/...le-alternative/
Install this, and set ''VB-audio virtual cable'' to be your default output and input devices. In foobar output select your output sound card..
In add location type: record://.
Click play.. All sound should go trough foobar..
This is what i was found when i wanted to integrate youtube into foobar. Problem is sound, and this is solution. For now, none is interested for this plugin.
I wish there was more interest for this...
It works but there is a few second delay between the sound and the video. I suppose I should have seen that coming but I can't watch any videos with people talking on them as it's just plain weird. Thanks anyway, now I at least know how to stream through foobar if I'm having a music marathon or listening to the radio.
you can use asio to set latency delay, don't now how because i never use it, but this will solve your problem..
Old thread...
Just FYI, there's software called ReClock (from SlySoft) which might be helpful in some synchronization cases ...
Re: Stream system audio from soundcard to foobar
You can minimize the delay in foobar -> preferences -> playback -> output.
Just set the Buffer length to minimum and all Fading buffers to zero.
But: this might arise new other issues.
Error: Unable to open item for playback (Unsupported file format): "record://"
Error: Unable to open item for playback (Unsupported file format): "linein://"
None of these work in Foobar. What works?
Opening record device requires foo_record component. If you are using foobar2000 v1.4 beta use this version. And with older foobar use this.
Thank you!  Now it makes sense. Works!  :))
I tried https://github.com/protyposis/LocalAudioBroadcast/ but I experienced audio quality issues. foo_out_upnp was the only software that I could get to stream sound without degraded quality.
