Amp power AVR vs Power amp
Reply #10 – 2013-12-31 14:11:16
Since almost all music these days is distributed digitally, it makes sense to stay in the digital domain all the way through the signal chain until you reach the speakers Maybe, but the thing is, most class-D amps are analogue as well. You could feed it directly with a pulse train, but usually that pulse train is generated by combining the (analogue) input with a sawtooth wave. That's way off-topic however.So a 100 watt Sony AVR and a 100 watt Pass Labs will have the Pass Labs having a much greater current delivery into low impedances due to the much larger power supply sections. Not really, no. The size of a power supply does not say much about the amount of power it can safely deliver. Furthermore, it might be that the power supply is oversized and that the actual amplifier section is the bottleneck.So this high current supply will always benefit the speaker? No, because it might not be the weakest link in terms of power output of the system.If the Sony amp was not clipping at a certain output, does that mean it was supplying all the current the speaker needed? Things all interconnect. You can't talk about current while excluding impedance, voltage and power. The speaker doesn't 'need' a current, there is a current flowing because of the voltage across the voice coil and it's impedance. There is no more simplifying or breaking it down to elements here, really.
