Topic: Lyrics panel not working (Read 1565 times) previous topic - next topic
Hello,
I have a problem with my x360 config in which I can't setup the lyrics panel. I have a lyrics v2 which is not working, so I probably will need v3 version. Problem is, that I can't install it and put it the place of prevoius version in my skin layout. Could you help to install it, please?
This is a position of lyrics panel.
Link
Preferences:components
Core (2013-11-07 13:06:20 UTC)
foobar2000 core 1.3 beta 5
foo_albumlist.dll (2013-11-07 13:03:16 UTC)
Album List 4.5
foo_cdartdisplay.dll (2011-07-29 14:07:08 UTC)
CD Art Display Interface 3.0.145
foo_cdda.dll (2013-11-07 13:03:00 UTC)
CD Audio Decoder 3.0
foo_chronflow.dll (2008-04-13 22:16:00 UTC)
Chronial's Coverflow 0.3.0
foo_converter.dll (2013-11-07 13:02:42 UTC)
Converter 1.5
foo_dsp_eq.dll (2013-02-11 11:28:58 UTC)
Equalizer 1.0
foo_dsp_std.dll (2013-11-07 13:03:16 UTC)
Standard DSP Array 1.3
foo_fileops.dll (2013-02-11 11:28:10 UTC)
File Operations 2.2
foo_freedb2.dll (2013-02-11 11:27:56 UTC)
Online Tagger 0.7
foo_input_std.dll (2013-11-07 13:06:20 UTC)
Standard Input Array 1.0
foo_rgscan.dll (2013-11-07 13:02:30 UTC)
ReplayGain Scanner 2.2
foo_ui_columns.dll (2010-01-09 14:40:30 UTC)
Columns UI 0.3.8.3
foo_ui_std.dll (2013-11-07 13:06:20 UTC)
Default User Interface 0.9.5
foo_uie_biography.dll (2010-01-23 16:58:36 UTC)
Biography View 0.4.0.3
foo_uie_elplaylist.dll (2010-02-20 00:57:06 UTC)
ELPlaylist 0.6.7.0(beta)
foo_uie_explorer.dll (2009-05-11 02:37:30 UTC)
Explorer Tree 1.04.7c
foo_uie_graphical_browser.dll (2008-04-19 19:37:54 UTC)
Graphical Browser rev015
foo_uie_library_tree.dll (2010-01-30 23:17:14 UTC)
Library Tree 0.3.4.3
foo_uie_lyrics2.dll (2010-02-02 23:35:08 UTC)
Lyric Show Panel 2 0.4.6.12
foo_uie_panel_splitter.dll (2009-11-26 00:03:32 UTC)
Panel Stack Splitter 0.3.8.2(alpha)
foo_uie_quicksearch.dll (2007-05-18 12:31:10 UTC)
Quick Search Toolbar 2.8l
foo_uie_vis_channel_spectrum.dll (2008-05-18 02:02:12 UTC)
Channel Spectrum panel 0.17.2
foo_uie_wsh_panel_mod.dll (2010-01-28 05:51:58 UTC)
WSH Panel Mod 1.3.1
foo_unpack.dll (2013-02-11 11:28:10 UTC)
ZIP/GZIP/RAR Reader 1.6
foo_utils.dll (2008-02-08 21:26:58 UTC)
Playlist Tools 0.6.2 beta 6
foo_vis_shpeck.dll (2009-09-24 18:19:58 UTC)
Shpeck - Winamp vis plugins wrapper 0.3.6
File/Preferences/Columns Ui. Select the layout tab. Locate the panel stack splitter containing lyrics2. Right click the panel stack splitter and choose insert panel. Add lyrics3 panel. In panel stack splitter ensure all the panel settings are the same as for lyrics2 - in particular ensure forced layout setting is correct. Also you must rename the caption name of lyrics3 so it matches that used previously for lyrics2 else it probably won't be recognised by the code and won't display (or edit all instances in the code and change to the name used for lyrics3). Lyrics2 can be removed.
working perfectly THANK YOU!! :*
actually i'd have other thing even.
In this foobar skin there is possibility to have foobar player windows without windows border (buttons of minimalization, max, exit). Is there a possibility to improve x360 in that way?
The ability to disable standard parts of the Windows interface has been specifically disallowed by the developers and will not be discussed here.
