Topic: New Public Multiformat Listening Test (Jan 2014) (Read 152132 times) previous topic - next topic
Reply #175
My vote goes for:
Opus
Vorbis
Apple/FhG AAC
Helix Mp3, 128 kb/s
FAAC at 96 kb/s as low anchor
As for the decision between Apple and FhG AAC it might be a good idea to do a seperate listening test for these with similar samples after the "big" one is finished.
Reply #176
I'm about to do some investigation about the exact details how to use these encoders.
Great. I'm concern only about FhG libfdk as I couldn't get 96 kbps setting for it on a bunch of heterogeneous albums.
Reply #177
IgorC, I vote for FAAC -b 96 as a low anchor (please, complete my vote). Lower bitrate will make differences hearable for deaf even, but we don't need them in our test
Totally agree
Reply #178
Has FhG fdk VBR 80 or 96 kbps mode?
fdkaac.exe -m 1 (libfdk-aac 3.4.12) gave me 94.1 for the whole Shpongle album
keeping audio clear together - soundexpert.org
Reply #179
Did you see my earlier reply ?
http://www.hydrogenaudio.org/forums/index....st&p=852904
Reply #180
I took several albums from my media library and encoded them with fhgaacenc / fdkaac / qaac. The results are:
1) FhG AAC (quality 1 / 2 / 3 / 4 / 5 / 6):
37 / 68 / 105 / 138 / 206 / 256 kbps
2) FDK AAC (quality 1 / 2 / 3 / 4 / 5):
84 / 91 / 106 / 130 / 220 kbps
3) QAAC (--rate keep --tvbr N, N = 0 / 9 / 18 / 27 / 36 / 45 / 54 / 63 / 73 / 82 / 91 / 100 / 109 / 118 / 127):
46 / 53 / 61 / 70 / 76 / 96 / 111 / 126 / 144 / 161 / 196 / 231 / 264 / 295 / 333 kbps
(--rate keep is the default setting for qaac)
4) QAAC --cvbr 96 gives 101 kbps.
added:
5) Opus 1.1 --bitrate 96 / 104 => 99 / 107 kbps.
6) aotuv 6.03 -q 2 / -q 2.5 / -q 2.99 => 98.4 / 104 / 109 kbps
7) LAME 3.99.5 -V 7 / 6.5 / 6.449 / 6 / 5 / 4.999 => 101 / 106 / 109/ 114 / 129 / 136
Reply #181
As for libFDK, VBR target bitrate seems to be declared in https://github.com/mstorsjo/fdk-aac/blob/ma.../src/aacenc.cpp as the following:
static const CONFIG_TAB_ENTRY_VBR configTabVBR[] = {
  {AACENC_BR_MODE_CBR,   {     0,     0}} ,
  {AACENC_BR_MODE_VBR_1, { 32000, 20000}} ,
  {AACENC_BR_MODE_VBR_2, { 40000, 32000}} ,
  {AACENC_BR_MODE_VBR_3, { 56000, 48000}} ,
  {AACENC_BR_MODE_VBR_4, { 72000, 64000}} ,
  {AACENC_BR_MODE_VBR_5, {112000, 96000}}
First column is bitrate mode (you can set it by -m switch in case of fdkaac frontend), second column is for mono, third column is for stereo, for which you have to multiply by 2 to get actual target bitrate. So, -m 3 should target 96kbps (48000 x 2).
Reply #182
My result for the AAC encoders (similar to what was written before), achieved with my standard test set of various pop music:
Apple --tvbr 45 (or similiar):    93 kbps
Apple --tvbr 54 (or similiar):  108 kbps
Apple --cvbr 96 (or similiar):  100 kbps
Winamp FhG VBR 3:              102 kbps
fdkaac --bitrate-mode 3:        103 kbps
Because of the fact, that quality demands can be chosen only in steps here, the most adequate settings for the test are IMO
@2012: I don't like to see the encoders tested using lowpasses <16 kHz. It could alter quality just because of this (not necessarily towards the bad side).
lame3995o -Q1.7 --lowpass 17
Reply #183
I also could not get the declared bitrates. -m1 gives ~94kbps. Is something wrong with the encoder?
Reply #184
It's just one single album. Have You tried to run it on something else?  A few other albums?
Yes, I've seen it.  I was just expecting other people to answer it. And halb27 did it.
Reply #185
The default lowpass value for fdkaac -m 2 is ~13.1 kHz, for -m 3 it is ~14.3 kHz.
Reply #186
OK, this changes things. Nonetheless I feel uncomfortable to modify lowpass this way.
But wait: how can we do better with a lowpass at 14 kHz when default lowpass is 14.3 kHz?
Reply #187
My vote goes for:
Opus
Vorbis
Apple/FhG AAC
Helix Mp3, 128 kb/s
Guys, please specify which versions and settings. Fhg Winamp or libfdk? vbr, cbr?
What we should expect from pre-testing Apple and FhG AAC? According to the last test they have similar performance.  Both encoders were updated, but as far as I can see those are misc. updates.
So You can make your own blind test and bring it here.
Reply #188
I finished the Opus test for my test set of various pop music, and it matches perfectly my suggestion for the AAC settings:
Opus --bitrate 96: 101 kbps
Apple --cvbr 96 (or similar): 100 kbps
Reply #189
Thank You, halb27,lvqcl and nu774 for bitrate reports.  Later we will do a table with all bitrate reports.
Let's see what bitrates other people are getting.
Reply #190
Let use one fhg libdfk encoder as a reference.
Where we can get the "official" binaries?
Reply #191
As for mp3 I've just done some listening tests with Helix -V60, lame3995m -V5, lame3100m -V5.
I'd like to see lame3100m -V5 in the test. 3.100alpha2 has very noticeable advantages on tonal problems over 3.99.5, and my extension gives the chance for a better quality for transient stuff or whenever standard Lame might show up weaknesses with short or mixed blocks.
So all in all I'd like to see
Opus --bitrate 96
Apple AAC --cvbr 96
Winamp FhG AAC VBR 3
lame3100m -V5
in the test.
Reply #192
We're considering to include 4 codecs, that is already high.
That's the average number of codecs is proposed by people.
Reply #193
Enable AAC_HE profile with VBR 2
Enable AAC_HE_V2 profile with VBR 1
With ffmpeg, you can do this with -profile:a aac_he{,v2}. Or you can use the -t parameter in aac-enc.
Reply #194
Reread what lvqcl wrote.
VBR 3 defaults to 14.3k lowpass.
VBR 2 defaults to 13.1k lowpass.
VBR 3 gives us ~110kbps. That's why I suggested VBR 2 with 14k lowpass which gives us ~96-100kbps in my limited tests.
Reply #195
We're considering to include 4 codecs ...
OK, so:
Opus --bitrate 96
Apple AAC --cvbr 96
Reply #196
Yeah, it seems to be the intended usage, although nothing can stop us from using different combination  https://github.com/mstorsjo/fdk-aac/blob/ma...src/qc_main.cpp:
static const TAB_VBR_QUAL_FACTOR tableVbrQualFactor[] = {
  {QCDATA_BR_MODE_CBR,   FL2FXCONST_DBL(0.00f)},
  {QCDATA_BR_MODE_VBR_1, FL2FXCONST_DBL(0.160f)}, /* 32 kbps mono   AAC-LC + SBR + PS */
  {QCDATA_BR_MODE_VBR_2, FL2FXCONST_DBL(0.148f)}, /* 64 kbps stereo AAC-LC + SBR      */
  {QCDATA_BR_MODE_VBR_3, FL2FXCONST_DBL(0.135f)}, /* 80 - 96 kbps stereo AAC-LC       */
  {QCDATA_BR_MODE_VBR_4, FL2FXCONST_DBL(0.111f)}, /* 128 kbps stereo AAC-LC           */
  {QCDATA_BR_MODE_VBR_5, FL2FXCONST_DBL(0.070f)}, /* 192 kbps stereo AAC-LC           */
  {QCDATA_BR_MODE_SFR,   FL2FXCONST_DBL(0.00f)},
  {QCDATA_BR_MODE_FF,    FL2FXCONST_DBL(0.00f)}
IIRC setting VBR mode 1 on LC was not possible in the past.
Anyway, I have to note that VBR mode 1-5 is undocumented on aacEncoder.pdf and aacenc_lib.h.
Reply #197
In the event that increase bitrate up to 110, I'm right now can't guess whether encoders could be winner. Test would be more intricate but it's interesting.
And if to test Opus at 48 KHz sources, he can much go up at list quality, in the final analysis Opus 1.0 to sound noisy in any bitrate, IMHO.
Reply #198
1) Musepack at 96kbps will have lowpass ~14kHz. That's too low IMHO.
So it's acceptable for AAC, but not for Musepack? I realize that interest in Muepack is low, and that it likely will not perform that well. But at least arguments should be consistent.
Reply #199
Although my music is predominantly lossless, I just listened 2x 2hours to 20 of my favorite songs, which I encoded with Opus 1.1 to 80 and 96kbps. Eventhough it was just casual listening, there actually wasn't a moment I could tell I was listening to lossy music! I was thus really surprised by the transparency of 80kbps. This leads my to believe that testing 96kbps is overkill and will be very hard!
My votes therefor go to:
Opus 1.1 - 80kbps (--bitrate 80)
Aac (Apple) - 80kbps*
Vorbis (aoTuVb6.03) - 80kbps (-q1)
Mp3 (Lame 3.99.5) - 80kbps (-b 80)
*I never encode to aac, so I know nothing about settings and which version is better, but as the title of this thread is "Multiformat Listening Test" it would only be logical to put forward 1 aac contestant.
