Topic: Problem with AccurateRip (Read 1485 times) previous topic - next topic
Hi friends, i have a problem with accuraterip, i've ripped Eminem's Recovery Disc and it's accurate with confidence 200, but when i rip Eminem's MMLP2, it says not accurate and confidence is 2, tested with EAC,dBPoweramp and Foobar2000, my drive is iHAS524B and it's offset correction is +6, when i put Eminem's Recovery Album CD into drive those software automatically configure my drive for rips to be accurate, but before that when i put MMLP2, it can't configure, what is the problem ? why MMLP2 rip isn't accurate ?
  • Last Edit: 30 November, 2013, 09:10:57 AM by sasan50cent
  • spoon
  • Administrator
As it is a new CD (out in the last number of weeks), it is likely the disc you are ripping is different to the disc in AccurateRip, the update next week to AccurateRip will most likely add this disc to the database.
  • greynol
  • Global Moderator
I don't know what the other programs are saying, but EAC never told you the rip was not accurate.
Thanks for the reply man :-)
