Topic: Differentiating human voice from other sounds like horn, tapping, bird (Read 4995 times) previous topic - next topic
Hi all :-),
I am currently working on an academic project to find the human speech in the varying SNR conditions. I have implemented a method (using SNR band energy and SNR peaks in frequency domain) and is working fine to detect the voice activity but failing to detect only human speech. Currently I am failing to detect only human speech. I have tried with the speech feature extraction, but not able to make the decisions as thresholds values are varying for different environments.
Please do some one suggest how to detect only human voice activity. Any suggestions will be very helpful.
Thank you,
ksam917
If it's an academic project you should have access to many relevant journals and papers on the same or similar subjects which will get you started.
Just a hint - thresholds should not be absolute, they should be adaptive/relative. Absolute thresholds work only in a well defined/controlled environment. Have you tried some sort of normalization of the extracted features?
I have access to Journal, but not finding the suitable ones, and confused with from where to start and ow to proceed.
Yeah I agree with you. The set thresholds are varying for the different environments. if we do normalization also these values will keep on varying right. How to set the adaptive  thresholds?
Consult your academic supervisor. Doing an academic project without any sort of supervision/leadership sucks and is a huge waste of time, in my opinion (been there, done that).
