Topic: Xing Header - Quality Indicator (Read 2238 times) previous topic - next topic
  • Iggy64
I rip CDs to FLAC and to mp3.  For mp3, I use LAME with -V0 (best quality VBR).  Generally, I find that the mp3 sound pretty much the same to me as the FLAC for the rock and even the jazz I typically play -- even on my better equipment.
Recently, I started looking more closely at the headers in my mp3 files, and got interested in learning more about the LAME header.  The associated XING header - which is added with VBR encoding - contains a "Quality" indicator.  When I use mp3diags to examine the XING headers for my files, it generally says quality=100, or sometimes as low as quality=97.  At first I thought this was good.  However, when I read up on the XING header spec, the I found that this 4-byte field is
"Quality indicator as Big-Endian DWORD
from 0 - best quality to 100 - worst quality (optional)"
I found similar references elsewhere.  That is, there is agreement that 100=worst and 0=best.
I am baffled.  I used the -V0 option.  My files sound great (to me).  How can they be "worst quality"?
Am I misinterpreting something here?
  • lvqcl
  • Iggy64
Thank you very much, lvqcl.
Very interesting!  I'm glad that you have a reference with the reverse rating.  It makes more sense, given how I encoded my files.
Several references have it the other way:
On that very same page you cited, just a couple of paragraphs above, it says
//    ZONE A - Traditional Xing VBR Tag data
//    4 bytes for Header Tag
//    4 bytes for Header Flags
//  100 bytes for entry (NUMTOCENTRIES)
//    4 bytes for FRAME SIZE
//    4 bytes for STREAM_SIZE
//    4 bytes for VBR SCALE. a VBR quality indicator: 0=best 100=worst
And here
http://www.codeproject.com/Articles/8295/M...io-Frame-Header
it says
8, 12, 16, 108, 112 or 116    4    Quality indicator as Big-Endian DWORD
Strange.
Many thanks for your kind reply!
