Topic: RareWares Debian GNU/Linux Repository (Read 79941 times) previous topic - next topic
Reply #75
<3
Reply #76
thanks for the love
i just updated the first post with the most current info (and will do some more adding in a sec).
also, i'll be following the zen kernel patchset (a project from the gentoo forum) and packaging new kernels (both k8 and 686 - only k8 is available right now). currently i have the kamikaze patchset (precursor to zen) at it's last stable release.
you can read about zen here:
http://forums.gentoo.org/viewtopic-t-641834.html
http://forums.gentoo.org/viewtopic-t-616535.html
and the 2.6.23-kamikaze5 patch here:
http://forums.gentoo.org/viewtopic-t-608387.html
later
Reply #77
Any chance of seeing 64 bit packages in the near future? The small amount of packages in the amd64 section are all very old.
Reply #78
chance? yes.
plans - no.
i need to change organizational and build processes first. right now it's very basic.
later
Reply #79
I have had tonnes and tonnes of troubles with continuing my audio life after switching to linux, but thanks to this, I can finally set my troubles aside. I can't say how greatful I am to you guys for having a dedicated audio geek oriented repository with the latest packages of every software. Thanks once again.
PS: I am slightly n00bish in my experience with repos, so can someone please give me an apt line that I may add to my /var/apt/sources.list file ?
Reply #80
Hi MetalheadGautham ,
As it says here you need the following repos (can just add the code below directly into sources.list):
 ## RareWares/Debian Multi-Media Repository for Unstable
deb http://www.rarewares.org/debian/packages/unstable/ ./
## RareWares/Debian Multi-Media Repository for Unstable - Experimental Staging
deb http://www.rarewares.org/debian/packages/experimental/ ./
## Christian Marillat's Mult-Media Repository for Unstable
deb http://www.debian-multimedia.org sid main
## Christian Marillat's Mult-Media Repository for Unstable - Experimental Staging
deb http://www.debian-multimedia.org experimental main
The debian-multimedia.org repos are needed since there are some packages have dependancies in them.
Cheers, Arite.
Reply #81
lots of changes...
from cvs/svn:
* wavpack
* lame
* k3b
* libvorbis-svn
* cuetools (also, libcuefile broken out dynamically for musepack from SVN)
* musepack sv8 (NOTE: THIS WILL SOON BE IN UNSTABLE! CURRENTLY IN EXPERIMENTAL!)
* xmms-musepack-sv8
* libreplaygain (from musepack svn)
* ktorrent-svn
updated:
* libvorbis-aotuv (b5.5)
* oggenc-aotuv (1.2.0)
* oggenc-svn (1.2.0)
removed:
* bmp plugins (old)
* flac-cvs (old)
* flake-enc (officially packaged now)
* soundkonverter (officially packaged now)
* gstreamer08-monkeysaudio (old)
kernels:
* 2.6.26-rc3-zen0 (for core2 and k8 dual core systems)
and a fun exclusive...
nvidia packages:
* the beta release (173.08) packaged for debian only found right here! created by yours truly!
* the nvidia source package is patched to build against any kernel (up to 2.6.26-rc3 atm)
later
Reply #82
Thanks its working great. I am running Testing with a little bit of Sid.
Reply #83
Nice
What does "* flake-enc (officially packaged now)" mean? Flake is now the official flac encoder?
And it's still 32bit only, I presume?
Reply #84
i'm glad to hear the repo is working for testing, also  - thanks shadowking.
and to answer your questions, brent:
after an official debian maintainer picks up a package i have been providing i no longer continue packaging it.
that is usually true unless cvs/svn/alpha upstream releases would not be packaged by the official maintainer (i.e. why i package wavpack alphas/betas, etc.)
if you are using flake-enc, please do the following to change to the official packages:
"apt-get update && apt-get install flake flake-enc-"
...that will remove the package i've created and download the official ones.
i only do 32bit still, yes.
later
