Topic: Updated version of udial.wav (Read 3281 times) previous topic - next topic
  • bandpass
Re the discussion here.
Updated, slightly less dangerous version of udial.wav:
* Inaudible to audible tone ratio of 10dB (udial.wav has 30dB).
* Constant, low noise-floor (udial.wav has audible wideband noise during the HF portion).
* Without the harsh attacks of the original sample.
Original, udial.wav:
Updated, udial10.flac:
N.B. "slightly less dangerous" does not mean safe!
ATTENTION: Play this sample at low volume, even if you hear nothing special! It can be very harmful to equipment and/or your ears.
It's strongly recommended to use some very cheap (PC) speakers if you want to test this,
otherwise you might really ruin your tweeters (it has happened several times already).
[ Specified attachment is not available ]
