Topic: headphones losing frequency response over time (Read 5466 times) previous topic - next topic
What causes this? Is it a problem that can be fixed?
I've had two pairs of headphones gone bad in this way. Both times, the lower mids almost completely disappeared after almost 2 years of use. Probably some bass gone as well. No amount of EQ would fix it.
Which model of  headphone ? This is surprising, I never got this on any headphone.
The first one was a pair of JVC headphones, and the pair i bought to replace it, which is what i'm using right now, is a pair of Sony MDR-G75 phones.
Granted, they're cheapo headsets but i could make them sound good with a fair amount of EQ-ing. And i take good care of my headphones. No drops or shocks.
(On a side note, i hate that ipods don't have any customizable EQ, but i found that the "R&B" setting comes close to my favored V-shape.)
I've never had this in any headphones I've had, from cheapo earbuds to expensive IEMs.
This might be a bad connection in common return (broken cable etc.). You can check that with a multimeter. If resistance from L to R (tip to ring) is noticeably off from the sum of L to return and R to return (tip or ring to sleeve, respectively), that would be highly suspect. With some luck, the defekt is at the plug and soldering on a new one fixes the issue.
Good thinking!!!
And open ground (common) creates the famous "vocal removal" effect, which removes the "center channel", including the lead vocal and bass.    A mono file will be silent, but with a stereo source you are listening in "mono" with the same sound in left & right ears.
If you open the ground connection to the headphones, leaving a common connection at the headphone-end, you loose the current path between the signal and ground.  But, you still have a path between the left & right signal-connections (through the common connection at the headphone-end).  Since current can't flow to/from ground, current will flow (and there will be sound) ONLY when there is a voltage difference between the left & right channels.
This usually can't happen with regular hi-fi stereo speakers, since each speaker has it's own ground connection to the amplifier.  But it can happen with computer speakers that connect to a soundcard using the same 3-wire connection/cable as headphones.
P.S.
Just FYI - Koss headphones have a lifetime warranty.  ...After a couple of failures, that may be important to you.
Which headphones?
I remember from the old times that earbuds would regularly "break" due to rough handling. The result was little to no bass and distorted.
"I hear it when I see it."
