Topic: FLAC (Read 2508 times) previous topic - next topic
  • bwssouth
FLAC
I received some songs which I am not sure if they are real flac.
The problem is that in log file of these songs, it says (Used output format : C:\Program Files\Exact Audio Copy\flac.exe  (User Defined Encoder)
                    192 kBit/s
)---does that mean that:
This is mp3 quality?
This flac has been made from mp3?
This is real flac?
What bitrate should have been used to reflect real flac?
Also I got some other songs where it says :
Selected bitrate                : 320 kBit/s
Quality                        : High
Add ID3 tag                    : No
Command line compressor        : C:\Programme\FLAC\flac.exe
Additional command line options : -5 -T "Artist=%a" -T "Title=%t" -T "Album=%g" -T "Date=%y" -T "Tracknumber=%n" -T "Genre=%m" %s -o %d
Here is more detailed description of first logfile:
EAC extraction logfile from 2. November 2013, 2:04 for CD
xyz
Used drive  : _NEC    DVD_RW ND-3550A  Adapter: 1  ID: 0
Read mode  : Secure with NO C2, accurate stream, disable cache
Read offset correction : 48
Overread into Lead-In and Lead-Out : No
                    192 kBit/s
                    Additional command line options : -8 -A tukey(0.25) -A gauss(0.1875) -b 4096 -V -T "artist=%a" -T "title=%t" -T "album=%g" -T "date=%y" -T "tracknumber=%n" -T "genre=%m" %s
Other options      :
    Delete leading and trailing silent blocks : No
    Installed external ASPI interface
  • greynol
  • Global Moderator
FLAC
http://wiki.hydrogenaudio.org/index.php?ti...ression_Options
If you're worried about quality and the title is commercially available, buy it.
