Topic: --until rejects files shorter than the given time; how to work around? (Read 3985 times) previous topic - next topic
  • 6string
I am running the following command as part of a script to process a wav to flac
flac --best --sample-rate=8000 --until=0:15.00 stream.part3.wav -f -o audio.flac
The issue I have is that I only want the first 15 seconds of the stream.part3.wav file (this file can vary in length)
However if the original file is less than 15 seconds flac returns an error and does not process the file
Does anyone know a way I could get around this
Thanks !!
  • d125q
You should be able to use something like shntool (http://www.etree.org/shnutils/shntool/) in order to see the length of the WAV file you're about to transcode. Afterwards, you can act accordingly -- if length < 15 seconds, transcode the entire file, else use --until=0:15.00 and transcode only the first 15 seconds.
If using other tools is not an option, perhaps you can infer the length by looking at the file size (use the stat GNU utility). Then, you can obtain the length (in seconds) like so (provided the the file size is given in bytes, which is what the  stat utility gives you):
length = (file_size * 8) / (sample_rate * bit_depth * channel_count)
  • Last Edit: 03 September, 2013, 01:01:08 PM by d125q
  • 6string
Thank you for the reply
It is a quite a bit above my pay grade so I have been trying to understand
So far I have added this to my script without success I figured I could adjust the 5000 number once I had a general idea of size:
SIZE =`stat %s stream.part3.wav | grep 'Size'`
if [ "$SIZE" !> "5000" ]
then
flac --best --sample-rate=8000 stream.part3.wav -f -o audio.flac
else
flac --best --sample-rate=8000 --until=0:14.00 stream.part3.wav -f -o audio.flac
In place of the original:
Don't want to be a pest so I will keep trying unless you see an easy fix
Thanks again
  • phofman
sox -V input.wav -r 8000 output.flac trim 0 15
  • 6string
Thanks for your response
I guess the reason I am having the issue in the first place was my inability to get flac file handler to work in sox
sox FAIL formats: no handler for file extension `flac'
  • 6string
Sweet your post gave me an idea
I used  sox to trim the file as a wav file (since the flac portion of my sox is not working)
Then I used flac to convert the trimmed wav file to a trimmed flac file
Now it is working for me
thank you all for your help !
  • phofman
Check your package manager. In deb based distributions and most likely in rpm based ones like centos sox formats are in separate packages:
aptitude search sox
p   libsox-dev                                             - Development files for the SoX library
i   libsox-fmt-all                                         - All SoX format libraries
i A libsox-fmt-alsa                                        - SoX alsa format I/O library
i A libsox-fmt-ao                                          - SoX Libao format I/O library
i A libsox-fmt-base                                        - Minimal set of SoX format libraries
i A libsox-fmt-ffmpeg                                      - SoX ffmpeg format library
i A libsox-fmt-mp3                                         - SoX MP3 format library
i A libsox-fmt-oss                                         - SoX OSS format I/O library
i A libsox-fmt-pulse                                       - SoX PulseAudio format I/O library
i A libsox1a                                               - SoX library of audio effects and processing
i   sox                                                    - Swiss army knife of sound processing
I always install libsox-fmt-all after installing sox.
