Topic: Can foobar determine whether the 36th character of a filename is a spa (Read 2743 times) previous topic - next topic
(Sorry about the the (ridiculous sounding) topic title, the last word was meant to be space.)
Hi all. Long story short, to facilitate compatibility between foobar and iTunes, I've been trying to find a way to truncate filenames above 40 characters (36 discounting the .mp3 extension), since iTunes cannot handle such long filenames. I've been using the renaming script "$cut(%tracknumber% %title%,36)" which has been pretty effective.
However, for truncated filenames, iTunes also disallows the last (i.e. 36th) character of a filename to be a space.
i.e., iTunes disallows "04 Ohm (Sommar Med Siv (Summer with ", automatically renaming it to "04 Ohm (Sommar Med Siv (Summer with".
In this case, I could use the script "$cut(%tracknumber% %title%,35)", but it would be a hassle to do this with multiple files all over the place.
So in layman terms, I'd like to know if there's a script that could perform something like: "if character 36 is a space, cut filename to 35 characters. otherwise cut to 36 characters".
Weird request, I know, but bear with me.  Cheers.
$trim($cut(%tracknumber% %title%,36))
Can we now turn this into the unofficial "giggle at iTunes" topic?
I still can not believe that iTunes really does not do something as trivial as file handling properly. Then again it is a widely installed piece of software. I guess it's the old rule of "worse is better".
EDIT: I found some relevant info regarding this... "bug":
http://www.ilounge.com/index.php/articles/...long-filenames/
https://discussions.apple.com/thread/3322627
https://discussions.apple.com/message/24144346#24144346
