Topic: Sort by date added to playlist (Read 2458 times) previous topic - next topic
I want to sort my libary by date added to liary.
How do i do that i used to some how with a code like %added% DURING LAST 1 WEEK SORT DESCENDING BY %added% or something but it dosent work now
Make sure you have the Playback Statistics component installed.
how to install a component: http://wiki.hydrogenaudio.org/index.php?ti...all_a_component
after doing that, using your original query would work had you been using it for some time. but if you've only just installed it, everything in your library is going to have an %added% date of today which isn't going to be of much use to you.
perhaps if you had a backup of your old foobar configuration folder, it might be possible to restore the database file from that but i really don't know.
Ok Thanks guys its all working now
