Topic: lame3100l - a constraint vbr variant (Read 35469 times) previous topic - next topic
I tried 30 diverse, both double-byte and single-byte file name wav files and it seems to be working. It's running more than 20x realtime on my Core i7 870.
I had to do another change in order to fix this:
a) With my last change I forgot to free up the memory allocated to take up the Unicode filenames.
b) I noticed that when invoking lame3100l from the cmd prompt, it was necessary to qualify the full lame3100l path in order to make use of mp3packer.
Please download again. Sorry.
lame3995o -Q1.7 --lowpass 17
I noticed that this encoder is rather slow on speech or silent content. I remember that the quality is perceptually worse in SSE version, so they can be something to do with denormals.
We were discussing about how MP3 handles sharp transients in electronic music
MP3 320 kbs vs Redbook ripped to WAV topic.
Here is a result for MP3 (~300 kbps) and AAC (~192 kbps) on EIG sample (electronic music with a lot of transients)
MP3 encoder > LAME 3.100l V0
AAC encoder > Apple, QAAC tvbr q90
files: here
Log:
ABC/HR Version 1.1 beta 2, 18 June 2004
Testname:
1L = E:\Audio\EIG\eig  LAME 3.100l V0.wav
2R = E:\Audio\EIG\eig Apple TVBR q90.wav
General Comments: A 2º sample is transparent
1L File: E:\Audio\EIG\eig  LAME 3.100l V0.wav
1L Rating: 3.8
1L Comment:
ABX Results:
Original vs E:\Audio\EIG\eig  LAME 3.100l V0.wav
    5 out of 5, pval = 0.031
MP3 isn't enough good while AAC is transparent.
Edit: As usual, MP3 suffers from very audible pre-echos.
I noticed the the lowpass in 3100L was changed back from 18200 to 17500 (as it was before 3100g). As I did not remember this mentioned anywhere, I hereby do. It might even happened accidentally (or I missed something).
BTW I found this at -V 1 and I know it isn't a problem but I think you should be aware of it.
Yes, lowpass is 17500 now for -V1, it's 18200 for a -V level better than 0.5.
