Topic: Tape artifacts (Read 16035 times) previous topic - next topic
Tape artifacts
3 sounds "gritty", basically you hear very short volume drops that are different on the left and right channel. No idea if it has a name except 'tape wear' or something.
Tape artifacts
Is that the artifact present on my last sample? (Artifact.wav)
How do I fix that?
Tape artifacts
Here's a recording to give you an impression of what audio quality can be obtained from a cassette, assuming good recording and playback quality. This tape is about 25 years old.
http://www.sendspace.com/file/b6uwtt
Tape artifacts
How do I fix that?
Yes! Unfortunately I really have no idea how you can fix it.
If it were a mono recording you could do something with combining information from the two channels, but for stereo recordings it's very hard to figure out if it's a wanted effect in the music or a bad tape. (I'm not saying it's impossible - WE can do it after all - but it's often not that easy to transform something that 'we' can do into software).
Storing tapes correctly and only playing them on high quality equipment helps... But it's too late for that now.
Tape artifacts
So if I hand this to a professional restorer, is he going to straight give it back to me?
or in other words, is this an unfixable artifact? (in the software realm)
Tape artifacts
Can somebody help?
What is this artifact called and how to fix it?
(it was previously hiss reduced and level equalized)
http://www.mediafire.com/listen/4z9csqv2zzd1kau/Artifact.wav
The artifact in the right channel at 4:48 looks and sounds to me like a drop out. I was able render it relatively harmless by copying  about 0.2 seconds at that point from the left channel and pasting it into the right channel.
Tape artifacts
Thanks a bunch Arnold!!
So indeed, this is food for meticulous work...
I can appreciate some denting as well in higher frequencies like in left channel 4.2, 4.32 or 4.63. So no (semi) automatic way for this kind of drop-outs right?
Tape artifacts
Reply #32
What about this "buzz" when voice gets in? It sounds kinda clipped audio, but I recorded it from tape (far from being clipped) and declipping doesn't show much improvement, I also tried with EQ but that's not. What is it and how to fix?
3Mb
http://www.mediafire.com/listen/f9skr1u435...f/chunk_RAW.wav
Tape artifacts
3Mb
Brutally clipped probably prior to being put on tape and then bandpass filtered.  A lost cause.
The clipping is particularly obvious both audibly and visibly between 1:018 and 1:538
